Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-04-2010, 08:01 AM   #1
aboatguy
CF Senior Member
aboatguy's Avatar
Default Airflow restrictions in intake track ?
I know someone is going to think hey dumbazz intake tract...
Is there a reliable way to check for air intake restrictions while datalogging without installing a vacuum gauge?
I believe it could be done by comparing the baro KPA(in HG) at the top of datamaster with the Map (HG) at WOT. However, I'm not sure if this is accurate or how much of a drop is normal/acceptable.
Here's a screenshot....(the code was fixed but not cleared...this was the check ride to see if everything was OK )
aboatguy is offline   Reply With Quote
Old 03-04-2010, 03:36 PM   #2
bjankuski
CF Senior Member
You can compare the baro KPA to the MAP KPA when the engine is off but the key on. If the readings are close when the engine is off then the reading will be accurate when it is running. Any difference greater then 3.5 KPA between the two at WOT is a restriction in my opinion.
bjankuski is offline   Reply With Quote
Old 03-04-2010, 07:15 PM   #3
rodj
CF Senior Member
rodj's Avatar
Quote:
Should they not be the at same static reading if no air is flowing in the intake ?
1 atmosphere / 101.3 Kpa / 29.92Hg /14.69 psi
rodj is offline   Reply With Quote
Old 03-05-2010, 08:42 AM   #4
bjankuski
CF Senior Member
They should be the same but the sensors may be calibrated slightly different. That is why you need to look at the difference with the key on engine off and then running to see what the change is from WOT. If there is a large change between the two readings the intake is a restriction. I cannot see your graph with this computer so I do not know what are displaying exactly but I took a quick look at the graph on another computer last night and it looks like there is a large restriction at WOT high RPM. What I saw was a MAP reading of 27.?? and a BAR readong of 30.??, that to me signals a large restriction if the throttle was wide open.
Old 03-05-2010, 10:29 AM   #5
JackDidley
CF Senior Member
JackDidley's Avatar
'Speed 146' You were having a pretty fun "check ride".
JackDidley is offline   Reply With Quote
Old 03-05-2010, 09:01 PM   #6
aboatguy
CF Senior Member
aboatguy's Avatar
MAP 27.9 and bar 30.19 2.29"hg.....if this is a big restriction whats the fix?
Old 03-05-2010, 10:18 PM   #7
rodj
CF Senior Member
rodj's Avatar
Would be interesting to see the pressure differential across a single plane carb intake @ WOT for comparision purposes
Old 03-06-2010, 09:20 AM   #8
bjankuski
CF Senior Member
Quote:
See if you can identify what the restriction is and remove the restriction. Clogged air cleaner or poor air cleaner, MAS to small or still has screens, poor air fliter housing, too small of a throttle body, intake ducting is too small or collapsing at WOT??
Old 03-06-2010, 09:24 AM   #9
bjankuski
CF Senior Member
I doubt the intake manifold is restriction. The restriction is probably the air intake system ahead of the intake manifold. The MAP sensor measures pressure in the intake and it cannot be used to determine if the intake itself is the restriction unless the throttle body holes are too small for the amount of air the engine is trying to use.
Old 03-06-2010, 09:57 AM   #10
aboatguy
CF Senior Member
aboatguy's Avatar
Went for another test ride...here's a shot of engine off.
and engine at WOT
58 MM tb, cut lid with KN filter, stock ducting.
Seems like the drop is 1.96" HG so is that bad or good at 6900+?
Mike
Old 03-06-2010, 01:56 PM   #11
bjankuski
CF Senior Member
It is not real bad but you are loosing about 7% of you avaialble power due to the intake restriction. In other words if you could get it to zero restriction you could gain 7% more power at 6900 RPM. Zero would be very difficult to acheive but even if you could get it to 1" of HG you could pick up 3.5% in power which could be 17HP on a 500 HP engine. A side note you do not need to go 154MPH to get these readings if you hit 6900 RPM in second gear it will also provide you the data you need. Where can you run that fast?
Old 03-07-2010, 10:30 AM   #12
aboatguy
CF Senior Member
aboatguy's Avatar
Thanks for the information...as for 2nd gear I can't go to WOT in first or second gear the tires will just go up in SMOKE........
Mike
Old 03-12-2010, 07:41 PM   #13
5abivt
CF Senior Member
5abivt's Avatar
Thanks for the information...as for 2nd gear I can't got WOT in first or second gear the tires will just go up in SMOKE........
Mike
Rofl I like your style !!!!!
5abivt is offline   Reply With Quote
Old 03-12-2010, 09:39 PM   #14
aboatguy
CF Senior Member
aboatguy's Avatar
Quote:
Thanks, I would have used the 7005 rpm screen shot but I was easing up on the pedal so I wouldn't hit the fuel cutoff
Old 05-16-2010, 11:47 AM   #15
HlhnEast
CF Senior Member
HlhnEast's Avatar
Holy Crap Mike! I gotta see this car! Next time I am in Covington, I will give ya a hollar if ya dont mind showing off.
Keep the shiny side up!
HlhnEast is offline   Reply With Quote
Old 05-22-2010, 11:52 PM   #16
aboatguy
CF Senior Member
aboatguy's Avatar
Honestly
theres not much to see its just a daily driven 95 vert with a couple of mods........
With the exception of LT headers and the Mez hd the engine looks bone stock....
However, if I'm around....drop me a line..........
Now back to the thread anyone have a lower restriction intake ......with proof that its lower restriction?
Old 06-27-2010, 01:46 PM   #17
aboatguy
CF Senior Member
aboatguy's Avatar
Its been a while ....anyone have proven high flow air intake system?
Reload this Page Airflow restrictions in intake track ?
Tags
air, c4, corvette, flow, intake, mas, restriction, sensor, testng
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
