Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-04-2010, 03:13 AM   #1
USAsOnlyWay
CF Senior Member
USAsOnlyWay's Avatar
Default Dyno run... huge spark advance spike after runs
Is this normal?
Spark will advance to 36 degrees then when the throttle is closed, spark advance jumps and plateaus at 47 degrees until about 2500 RPM. (The car is in gear, throttle closed, no brakes at this point.)
Is this normal? If not, is this bad?
Since max advance when on the throttle is 36 degrees, I do not know why it would jump to 47 like that.
Thanks in advance.
USAsOnlyWay is offline   Reply With Quote
Old 03-04-2010, 03:41 PM   #2
bjankuski
CF Senior Member
Quote:
Originally Posted by USAsOnlyWay View Post
Is this normal?
Thanks in advance.
This is normal, at light load high engine RPM and high engine vacuum the spark advance will be high because you need more advance to allow enough time for the lean and less dense mixture to burn. Flame speed is reduced when the mixture is lean and less dense so that is why the ignition advance goes up. I have seen more the 50 degrees of advance in low load high RPM conditions.
bjankuski is online now   Reply With Quote
Old 03-04-2010, 07:13 PM   #3
USAsOnlyWay
CF Senior Member
Awesome. Thanks for the explanation. I'm very relieved it is normal.
Thanks!
Reload this Page Dyno run... huge spark advance spike after runs
Tags
1994, advance, corvette, dyno, flo, normal, pro, spark
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
