Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-03-2010, 03:29 PM   #1
bcollid
CF Member
Default deverting the AIR pump for a Dyno Run
Is there an easy way to force the AIR pump to NOT send air into the exhaust or Cat so that I can get an accurate Air/Fuel ready from a wideband O2 sensor when I go to the dyno next week
bcollid is offline   Reply With Quote
Old 03-04-2010, 02:36 PM   #2
surfer92
CF Senior Member
Send a message via AIM to surfer92
Air pump only runs when engine is cold, once warm pump shuts down.
If you want a cold run, disconnect the pump for dyno run.
surfer92 is offline   Reply With Quote
Old 03-18-2010, 02:17 PM   #3
brownc00
CF Senior Member
brownc00's Avatar
Quote:
I've read that the ECM will lean out the system a bit when it is running the AIR pump to keep the A/F ratio in line with the extra air coming in from the pump. According to the doc I read, they said you should change the program to not allow AIR pump to run untill 254 degrees. That should prevent it from ever coming on.
brownc00 is offline   Reply With Quote
Reload this Page deverting the AIR pump for a Dyno Run
Tags
adyno, pumps
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
