Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-02-2010, 09:21 AM   #1
redsix
Junior Member
Default Cold start problems - using FAST ECM with wideband O2
Hi All,
I had my 85 tuned on a dyno after I installed the FAST and wideband O2 sensor. She drives very well indeed when hot, but on cold start (which the tuners couldn't touch as the car was warm when I arrived) I have the following problems:
1. Car will not run on her own from cranking - I have to 'catch' the throttle and tickle it for about 5 seconds, after which she idles - albeit roughly.
2. For the first 5 minutes of running, any attempt to enagage drive stalls the engine, UNLESS I rev to about 1500 and hold it there first. Again - in and out of drive when warm with no issues
3. On pulling away, she coughes and splutters with misfires - any additional throttle opening only makes matters worse.
I have tried playing with the various afterstart tables in the CCCOM software, but nothing I do seems to have any effect - and of course, I only get 5 minutes to try before she warms up and the problems go away!
Can anyone give me some simply instructions of what I should adjust to try and resolve these issues?
My first attempt was to try and adjust IAC position versus Temp - ie bring the idle speed up a bit to prevent stall on engaging drive. No effect on idle. I can see the IAC position resolutely tracking well shy of where I set it.
If you haven't already guessed, someone like me having access to laptop tuning is just plain dangerous! I know next to nithing!
So if anyone could give me any tips, I'd be very grateful.
BTW The base-idle is correctly set. That was a simple procedure even I could manage!
TIA
Regards
Steve
redsix is offline   Reply With Quote
Old 02-02-2010, 02:43 PM   #2
bjankuski
CF Senior Member
Quote:
Originally Posted by redsix View Post
Hi All,
TIA
Regards
Steve
You need to adjust the commanded AFR when cold to a richer number. When it is cold it will be in open loop and there should be a table for open loop operation. Move the cammanded AFR 10% richer when it is cold and see what it does.
I have not used the FAST software for a few months so I am not sure exactually where the table is but look for a commanded AFR table when in open loop.
bjankuski is offline   Reply With Quote
Old 02-05-2010, 08:24 AM   #3
redsix
Junior Member
Thank makes sense - thank you. I'll try it this weekend.
Reload this Page Cold start problems - using FAST ECM with wideband O2
Tags
ecm, fast, problems
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
