Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-29-2010, 10:44 AM   #1
neretva
Junior Member
Default WinALDL and USB
Hello to all!
I've bought an ALDL cable for my laptop with an USB port. I'd like to use the WinALDL software, but it only works with COMx ports (RS232). Does anyone solved it? If so, could you tell me how I could use the WinALDL with my USB cable?
Thank you very much!
neretva is offline   Reply With Quote
Old 01-30-2010, 01:03 PM   #2
frank1973
CF Member
frank1973's Avatar
By COMx do you mean 9 pin serial. If so you can get a USB to serial adapter.
frank1973 is offline   Reply With Quote
Old 01-30-2010, 01:04 PM   #3
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Quote:
Originally Posted by neretva View Post
Hello to all!
When your USB ALDL cable is properly installed with the correct drivers, it will show up as a COMx port.
Vis Croceus is offline   Reply With Quote
Old 01-30-2010, 10:14 PM   #4
neretva
Junior Member
Thank you for your responses! As soon as I receive the ALD cable I'll probe it and I'll tell you the results.
Old 02-08-2010, 11:23 AM   #5
neretva
Junior Member
Hello to all!
I've received the USB cable and it works fine! I had to configure it to the "10Kohm between A-B" mode and the WinALDL to 4800 baud rate for the virtual serial port. Also I had to select the 1227165 ECM in the WinALDL configuration.
I've received some instructions with the cable, so it was very easy to do!
Cheers!!!
Reload this Page WinALDL and USB
Tags
1227165, 2010, aldl, cable, configure, corvette, driver, forum, laptop, port, reviews, serial, software, usb, winaldl, work
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
