Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-27-2010, 01:34 PM   #1
Stumpdeisel
CF Senior Member
Stumpdeisel's Avatar
Default Is there an easy wasy to test if an ECM is fried?
Well apparently it will be cheaper for me to buy a scanner or another used ECM to rule it out as my starting problem than getting someone to figure it out. $85/hr with no time or resolution guarantees doesn't work for me on my budget.
Is there an easier/cheaper way to test voltage on a certain pin/pins on a 93 ODB1 ECM to know if it's fried?
Also, I was considering an Actron scanner, but was told I was better off trying to find a used snapon with the appropriate diagnostics loaded up instead. They still seem very costly on fleabay, any recommendation as to which scanner to get to help me out?
Thanks all.
Stumpdeisel is offline   Reply With Quote
Old 02-04-2010, 02:31 AM   #2
surfer92
CF Senior Member
Send a message via AIM to surfer92
what is the doing?
You need a test light and a multi meter.
I have a FSM, so I can help with the pin out.
surfer92 is offline   Reply With Quote
Old 02-04-2010, 11:35 AM   #3
Stumpdeisel
CF Senior Member
Quote:
Originally Posted by surfer92 View Post
what is the doing?
Thanks surfer!
I have both a test light and multimeter, and am considering getting a noid light which is pretty cheap as well to help me figure this out.
Besides spark I realize even though I have good pressure in the rails the injectors may not be pulsing.
Any pin-out info you have would help tremendously! Either post it here or PM me, or email me at stumpdeisel@yahoo.com
Thanks Again!
Rick
Old 02-05-2010, 12:38 AM   #4
coupeguy2001
CF Senior Member
coupeguy2001's Avatar
Send a message via AIM to coupeguy2001
check fuses Then Do a diagnostic.
short out pins A&B on the aldl. turn the key to on but don't try to start the car. the fan will run.
the check engine light will flash once pause, then twice. repeat.
Then count the flashes. they will be in 2 digit segments. like two flashes, then 4 flashes. then a pause, then more flashes. for instance, 24 or 32 etc.
use a pad and pen to mark them down so that when they repeat, you can verify.
If it goes into diagnostic, it is probably ok.
Then use an analog meter, pin onto the injector connector, black is ground, pink and black or green and purple are the pulse wires.
The meter needle will go upscale every pulse. use 24 volt scale first, then click down one notch until you are comfy with needle deflection.
check one injector on left side, one on the right. since they are ganged together.
If the volts are ok, then take the distributor module to auto zone or checker, and have them check it.
If no ignition pulses, it's the module.
coupeguy2001 is offline   Reply With Quote
Old 02-05-2010, 01:51 PM   #5
Stumpdeisel
CF Senior Member
Thanks Coupeguy2001!
Great info, as soon as I can check this in the garage without freezing by butt off I'm all over it.
Old 02-09-2010, 11:56 AM   #6
Stumpdeisel
CF Senior Member
Default Good NOID light for ODB1 Motors?
I found this noid light set for 25 bucks, is that a fair price and is this a good set?
ATD 5612 11 Pc. Noid Light Set w/Ext Lead&2 GM IAC Ind
Reload this Page Is there an easy wasy to test if an ECM is fried?
Tags
85, analog, c4, corvette, distributor, ecm, fried, fry, frying, injector, module, multimeter, ping, pinout, testing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
