Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-26-2010, 01:47 PM   #1
Stumpdeisel
CF Senior Member
Stumpdeisel's Avatar
Default LT1 ODB1 - No Spark: Any LI NY Mechanic recommendations?
After many house projects (never will be done hehe) and a big wedding last October done and paid for, it's time to get my project running.
It's a 70 coupe restomod with a rebuilt camaro LT1. The motor was convertd to ODB1 and uses a painless harness. My sign has a cardomain link 4 pages long if you care to take a look.
Here's the deal:
*It has fuel pressure in the rails (have an FP guage on the rail regulator)
*The harness light as per painless is on constant during startup indicating correct power and ground connections, and there is voltage at the distributor modules, injectors and optispark.
*It has a retuned PCM with VATS turned off.
The car turns over but will not fire up. I have no PCM, noid lights or other diagnostic tools to determine if it's the PCM, some sensor code or sensor issue.
So, The wife will help pony up some cash to get this thing running finally, and am looking for recommendations for a reputable shop on Long Island NY that won't charge an arm and a leg to at least diagnose why this thing won't fire up.
Stumpdeisel is offline   Reply With Quote
Old 02-02-2010, 05:32 PM   #2
surfer92
CF Senior Member
Send a message via AIM to surfer92
What is the FP?
Does it have spark at the plugs?
Have you checked the wiring for broken wires or insulation, especially at the connections?
surfer92 is offline   Reply With Quote
Reload this Page LT1 ODB1 - No Spark: Any LI NY Mechanic recommendations?
Tags
corvette, flash, lt1, odb1, spark
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
