Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-10-2010, 03:43 AM   #1
kiwivetten
Junior Member
Default Anyone have a copy of ANHU BIN file?
I have been trying to install and Ostrich but have had no luck getting it working. Just worked out that I need an ANHU BIN and not the AUJP which is the common BIN on the Third Gen forum.
This BIN isn't listed on Moates or DIY-EFI.
Doe anyone know where I can get a copy. If not I will need to find someone with an EPROM programmer to download the BIN.
kiwivetten is offline   Reply With Quote
Old 01-10-2010, 04:10 AM   #2
rodj
CF Senior Member
rodj's Avatar
Quote:
PM me
AUJP is a '90 F-body bin
'90 Vette auto bins ANHT or ANFJ (from Moates ) should work
rodj is offline   Reply With Quote
Old 01-10-2010, 03:07 PM   #3
kiwivetten
Junior Member
I tried the ANHT BIN and it does not work. Radiator electric fan runs full time and engine runs rough (but better than AUJP!). Also found another post which says it does not work. ANHW is apparently very similar but with a different rear end gear. This BIN also isn't on Moates or DIY-EFI.
Old 01-10-2010, 08:11 PM   #4
JackDidley
CF Senior Member
JackDidley's Avatar
I found a modified AHNU here. Pretty sure its modded to run open loop . I did not really look at it.
http://www.thirdgen.org/techboard/di...ggestions.html
JackDidley is offline   Reply With Quote
Old 01-12-2010, 08:44 AM   #5
woodstock
CF Member
Send me an e-mail. I read out the ANHU prom myself, 100% stock!
With the fans running right away, you're in limp home mode.
woodstock is offline   Reply With Quote
Reload this Page Anyone have a copy of ANHU BIN file?
Tags
anht, anhu, bin, prom, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
