Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-09-2010, 12:58 PM   #1
gtspeed98
Junior Member
Default Electrical issue
'95 coupe auto. While driving "SYS" will flash three times then go back to mpg readout. Owners manual states "may be a problem with your electrical system" It seems to drive fine. Recently changed OEM stereo to aftermarket using wiring harness from Crutchfield. The cruise control was not engaging last time I drove the car.
I was going to un hook stereo first, then check connections for cruse control. Any other areas to check when it warms up a bit.
GTSpeed98
gtspeed98 is offline   Reply With Quote
Old 01-09-2010, 06:47 PM   #2
rodj
CF Senior Member
rodj's Avatar
Did you install resistors on the stereo lighting circuit?
If not SYS will flash because system is looking for circuits that are not there with aftermarket setups
http://www.corvetteforum.net/c4/dave8476/index4.shtml
rodj is offline   Reply With Quote
Old 01-10-2010, 11:39 AM   #3
gtspeed98
Junior Member
Thank youfor your quick response. No I didn't. Do I put it inline on the wire for lighting and what value resistor? When I bought the wire harness and antenna extension from Crutchfield nothing was mentioned about the resistor.
Old 01-12-2010, 09:29 PM   #4
gtspeed98
Junior Member
Looked through bulletin, noticed the it relatetes to '90 - '93 with electronic air which pertains to my '92. My '95 has manual air. The aftermarket radio has a circuit board no wires.
Old 01-13-2010, 12:21 AM   #5
rodj
CF Senior Member
rodj's Avatar
Quote:
http://forums.corvetteforum.com/c4-t...sys-light.html
http://forums.corvetteforum.com/1559553067-post3.html
Reload this Page Electrical issue
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Electrical issue!?! Need Help Burland15 C5 Tech 9 05-27-2005 04:55 PM
1969 Vette Just Died When I Turned on the HeadLights bbecker C3 Tech/Performance 27 02-25-2005 06:36 PM
Electrical Issue (Windshield Wipers) Hiteck C5 Tech 14 10-08-2004 12:55 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
