Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-04-2010, 11:44 PM   #1
95BLKVette
CF Senior Member
95BLKVette's Avatar
Default Former LT-1 Edit Now Trying to Use TunerCat Tuner
Just purchased the $EE / $EEB ECM files for use with the Tuner 2.25V program. Was able to connect to my PCM and read the Bin file with my LT-1 Edit cable.
Question is, can't seem to find the fan temperature On / Off settings in Tuner and some of the other functions I can see in Lt-1 edit.
Does the program display these differently?
I basically was interested in Tuner as it can change the display fuel use settings as I have 30# injectors. You can't edit that in LT-1 edit.
Any comments are appreciated
95BLKVette is offline   Reply With Quote
Old 01-05-2010, 11:44 AM   #2
STL94LT1
CF Senior Member
STL94LT1's Avatar
Send a message via AIM to STL94LT1
Quote:
It is located about halfway down the second column of Tables, "Fan enable vs coolant temp vs speed".
__________________
2001 White/Black/Black Vert M6/Z51: LPE TT650 580rwhp/540rwtq
1994 White/Red M6 LT1 Corvette: 374rwhp/345rwtq,12.37@119: Heads/Cam/4.10's
2001 Ford Lightning: 425rwhp/503rwtq,12.85@108
2006 Cobalt LS (DD)
STL94LT1 is offline   Reply With Quote
Old 01-05-2010, 09:01 PM   #3
95BLKVette
CF Senior Member
95BLKVette's Avatar
Yes, but the table only shows 4 numbers that are apparently in MPH
Even when you graph it it's a diagonal line with mph on the left vertical axis and fan 1 to fan 2 along the bottom.
This is the table view:
Fan Enable Coolant Temp (Deg. C) Vs. Speed
Fan # MPH
Low High
1 79.25 79.25
2 85.25 85.25
Am I missing something?
Is there some formula combining the temp in the numbers?
__________________
10/99 95 Blk LT-1 Cpe 383 LT1, J&E Forged Pistons, Eagle Forged SIR Rods GM Hot Cam,1.6 RR, Ported Heads, 30# Injectors, PaceSetter Shorty Hdrs, 3" SS Exh, LT1-Edit, Accel 300+, 160 Thermo, Tbody Bypass, LT-4 Knock, 9" ProTorque 3,000, 129K mls (5/07) Self-rebuilt 4L60E
12/30/04 99 Torch Red Vert, Tan Int, Blk Top, Auto, 21K mls (5/07 58K mls). Twlt Sent, HUD, Pwr Lthr Sport Sts, Memry, CV Real Time Dmpg, Pwr Tele Str Whl, 12 CD Chngr, Dual Clmt Cntrl, Active Hdlg, Trctn Cntrl, Fog Lmps.
Old 01-05-2010, 09:46 PM   #4
STL94LT1
CF Senior Member
STL94LT1's Avatar
I don't know why they listed the values in mph, just ignore the mph and use Celsius.
__________________
2006 Cobalt LS (DD)
Old 01-05-2010, 11:29 PM   #5
95BLKVette
CF Senior Member
95BLKVette's Avatar
Gee thanks, that was easy.
BTW, how come in the ECM definition help file they don't list all the items you se in the table screen?
Would be very helpful if they did
__________________
Old 01-05-2010, 11:38 PM   #6
STL94LT1
CF Senior Member
STL94LT1's Avatar
TunerCat keeps updating their ECM files, guess the help section is lagging behind.
Also, on the fan changes I like my fan's on/off temps to be different temp settings. For example, Fan #1 low 82* high 85*, fan #2 low 87* high 90*.
Think how confusing all of these tables can be to the newbee tuner.
__________________
2006 Cobalt LS (DD)
Old 01-06-2010, 12:10 AM   #7
95BLKVette
CF Senior Member
95BLKVette's Avatar
Actually, I wonder if the program values you believe are on and off temperature limits actually are that!
This is the LT-1 edit user definitions for the high/low values:
Under each stage there are two settings, the PCM uses the first setting when the car speed in MPH is below the Fan Speed threshold, the second setting is used when the car road speed is over the Fan Speed threshold.
The Hysteresis is the temperature drop required before the fans turn off. The upper Hysteresis value is used when the road speed is below threshold, and the lower value is used when the road speed is above the threshold.
The values I see when I look at the same PCM file in the two programs are the under and over speed values, not lower and upper temperature values. I think I'm going to ask the TC guy to explain these....
BTW, I think I'm correct as the fan hysteresis values are in the ECM constants listing and they match my LT-1 edit definitions.
So, the values you think are low and high fan temps are actually fan turn on temps at below and above the MPH threshold.
The hysteresis is the deg C temp drop before the fans turn off.
Also, the MPH threshold speed is in the ECM constants list just below the hysteresis values and they match my zero speed value in LT-1 edit
__________________
Old 01-06-2010, 10:32 AM   #8
STL94LT1
CF Senior Member
STL94LT1's Avatar
In earlier versions of the $EE definition file the fans on/off were in the ECM Constant tables, which was less confusing. When I recieved an update of the def file I couldn't find the fan settings, so I emailed TC and they responded with the table "Fan enable vs coolant temp vs speed" controls the fan temps on/off.
Let me know what you find out.
-Mike
__________________
2006 Cobalt LS (DD)
Old 01-06-2010, 10:42 PM   #9
95BLKVette
CF Senior Member
95BLKVette's Avatar
TC hasn't responded yet, however, I know I'm correct based on comparing the values in LT-1 edit and tunercat using my bin to lt-1 file type converter....I can open the exact same data file information in each program and compare them side by side. Then I use the Lt-1 manual which has the details of what each value is that TC doesn't explain.
Like I stated before, the LT-1 edit hysterisis values are the same as the TC constant values, etc.
I don't know who told you that those table values were the low and high temperatures, but that is unfortunately not the case. They are the fan turn on C temps above and below the vehicle set mph for fan 1 & fan 2.
Sorry
Old 01-06-2010, 10:46 PM   #10
STL94LT1
CF Senior Member
STL94LT1's Avatar
No your wrong, I'm 100% sure that I'm right.
Care to place a friendly wager on it?
__________________
2006 Cobalt LS (DD)
Old 01-07-2010, 09:51 PM   #11
95BLKVette
CF Senior Member
95BLKVette's Avatar
I really appreciate your truly tactfull Opinion, but it's just that, an Opinion
Tuner Cat, LT-1 Edit, RT Tuner, etc. are all just ECM bin file readers/editors that permit editing the values in GM's original data tables. They cannot combine data or alter the arrangement of the data tables, nor add additional data items, as the ECM base operation system or BIOS programing would need to be altered. So, whatever LT-1 edit reads and defines, has to be the same in all the other edit programs. Your explanation of the table values unfortunatley does not agree with this logic.
We have too much invested in our vehicles to be guessing what controls what.
I'm a professional engineer, and not much of a gambler
I'd like to confirm the data fan table values definition from the author so all the Forum members can benefit.
Below is a copy of the email I just resent requesting a Yes/No response from TC on this topic:
Sorry to bother you again, but another member of the Corvette Forum is challenging me on this and we need to have a Yes or No from you on the following:
Thanks in advance......
Was discussing your fan enable temperture (C) vs speed table.
It shows 4 values.
When I lookup the same 4 values in LT-1 edit
They define them as follows:
Is this the same definition as for your values?
Thanks so much,
95BLKVette
__________________
Old 01-08-2010, 07:44 PM   #12
96z51
CF Senior Member
oh this should be good.
96z51 is offline   Reply With Quote
Old 01-08-2010, 08:05 PM   #13
STL94LT1
CF Senior Member
STL94LT1's Avatar
Default Response from TunerCat
"Sorry for the confusion. The Fan on/off points were recently moved to a table called 'Fan Enable Coolant Temp Vs. Speed' located in the tables section. This was done to free up some space to add some new constants. The help file hasn't been updated yet.
Best regards,
TC"
__________________
2006 Cobalt LS (DD)
Old 01-08-2010, 08:11 PM   #14
STL94LT1
CF Senior Member
STL94LT1's Avatar
Why doesn't this surprise me!!
__________________
2006 Cobalt LS (DD)
Old 01-10-2010, 11:24 AM   #15
95BLKVette
CF Senior Member
95BLKVette's Avatar
Quote:
Best regards,
TC"
Sorry, TC's explanation doesn't agree with with the table title....I wonder if they actually know whats in the ECM table!
Was almost ready to purchase the program as I have purchased the ECM constant file to see how it works.....
Staying with LT-1 edit...at least I know what its doing
__________________
Old 01-11-2010, 05:28 PM   #16
95BLKVette
CF Senior Member
95BLKVette's Avatar
The current response from TC as of today is in agreement with me as follows (this makes logical sense based on what is in the constant tables as I noted previously):
Hi Al,
Sorry I guess you didn't receive our last e-mail for some reason.
Yes, the temperatures in the Low column are used when the vehicle speed is less than the 'Fan High/Low Vehicle Speed Threshold' constant value. For speeds above this value the temperatures in the 'High' column are used.
Once the coolant temperature rises above these thresholds the fan will stay on until the coolant temperature drops below the threshold minus the 'Fan Temp. Hysteresis - Low Vehicle Speed' (or 'Fan Temp Hysteresis - High Vehicle Speed' depending on vehicle speed) constant value.
Best regards,
TC
__________________
Old 01-11-2010, 08:09 PM   #17
STL94LT1
CF Senior Member
STL94LT1's Avatar
Wow, some people just can't admit when they are WRONG!!!
__________________
2006 Cobalt LS (DD)
Old 01-11-2010, 08:38 PM   #18
95BLKVette
CF Senior Member
95BLKVette's Avatar
Yah, we're all waiting for you to fess up
It's just nice to know we finally know that the tables match the LT-1 definition, so Forum Members can basically reference the LT-1 Edit User Guide on the Tune It Up Website as a referenece point until TC updates the help file
__________________
Reload this Page Former LT-1 Edit Now Trying to Use TunerCat Tuner
Tags
cat, convertor, definition, edit, fan, file, files, lt, lt1, temperature, temps, tuner, tunercat
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
