Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-23-2009, 03:10 PM   #1
Mr.V
Junior Member
Default Newbie has Problems with lights
Hi Everyone,
I just learned of this Forum and joined so please forgive me if I'm not going about this in the right way.
I have a 1990 Black Corvette Convertible that I have owned since new.
It has 60,000 miles, has always been stored in winter except for the last two years since I started wintering in Florida.
Last year I went to Ecklers and replaced the driver side headlamp motor and module, since then the headlamps no longer automatically activate when it gets dark, also if I start the engine first and turn on the lights they will not rotate. I have to turn off the engine, turn on the lights manually and they will rotate. Also I recently noticed that the passenger side running light was out. When I replaced the bulb with a 2057 lamp I noticed that when the running lghts are on the signal lights can not be seen although they are working faintly, also when I turn on the head lamps both the signal and running light filaments light up as though they are receiving to much voltage and they get very hot.
Hope I am going about this in the right way!
Any suggestions would be most appreciated.
Thank You
Mr.V is offline   Reply With Quote
Old 12-23-2009, 05:22 PM   #2
Flame Red
CF Senior Member
Flame Red's Avatar
Welcome to the forum. I think you posted this in the wrong section. Better trying General Discussions or maybe Tech as you will get more responses there. This is the scan and tune section.
Perhaps the Canadian cars are different, but in the US, my 90 does not have auto lights on. I know there are aftermarket add-ons that will enable that feature.
I am wondering if the Canadian cars are different if the motor assembly might be different and the one you got from Eklers may be incompatible. Usually the motors need new plastic bushings to fix them. They are inexpensive ($5 or so) and can be installed with a little more work than removing the motor. I would check to see if the part numbers from your old motor is the same as the one Ekler's sent you.
As far as the other bulb issue, I wonder if you have a ground issue so it is not running enough current thru the bulb and so it is dim. Or perhaps the contacts are corroded.
However, the headlights should rotate engine on or off.
Not much help here, sorry.
Flame Red is offline   Reply With Quote
Old 12-23-2009, 05:43 PM   #3
Mr.V
Junior Member
Appreciate the reply and advice!
Apologize for posting in the wrong forum.
Thank You
Reload this Page Newbie has Problems with lights
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Headlights gone dark '90 Walt90 C4 Tech/Performance 11 05-02-2011 08:12 AM
Replacing stock stereo with aftermarket loses some functionality? Leorex C5 General 17 10-24-2004 11:44 AM
Sounds like crap to me Mr. Bill C5 Z06 Discussion 38 08-09-2003 12:57 PM
Coolant Temperature Sensor Question Tourney3p0 C4 Tech/Performance 26 06-23-2003 12:05 PM
Newbie Vette chick has problem with turn signal athena209 C4 Tech/Performance 26 06-21-2003 09:50 AM
Carb spacer (and more) information needed please! 71stingray454 C3 Tech/Performance 9 05-01-2002 04:13 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
