Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-09-2009, 03:32 AM   #1
2manytoyz
CF Senior Member
2manytoyz's Avatar
Default anyone wanna program a sd prom?
Anyone want to try in for a bolt on car?I still need a prop for a tpi car
does it need to be a sd prom/what all proms will work with my 90 6 speed car?
2manytoyz is offline   Reply With Quote
Old 12-09-2009, 03:44 AM   #2
2manytoyz
CF Senior Member
2manytoyz's Avatar
IM really interested to know if i get the eprom chip if i can use my tunercat software to read and program(i have the f-body y kit)Can program 94-96 vettes,w/def filesI bought the y kit.
Or would a hypertech be good enough?
Old 12-09-2009, 09:29 AM   #3
edcmat-l1
Supporting Vendor
edcmat-l1's Avatar
You'll need something like a moates autoprom, and tunercat RT.
edcmat-l1 is offline   Reply With Quote
Old 12-09-2009, 08:39 PM   #4
2manytoyz
CF Senior Member
2manytoyz's Avatar
I already have tunercat and freescan.Just wondering if anyone was already setup to program proms
Also i found out it must be from a tpi car,not sure if 5.0 and 5.7 matters but im betting on yes.
anyone have any experences with putting a chip on a l98,is it worth it?
Old 12-10-2009, 08:05 AM   #5
rodj
CF Senior Member
rodj's Avatar
Quote:
Needs to be from a 350 TPI, ( different fueling , different knock sensor for starters )
I believe a 90 -92 F body memcal will work in a Vette , but not other way around
What chip?
Any of the off the shelf chips are too generic and not worth the money
rodj is offline   Reply With Quote
Old 12-12-2009, 09:02 AM   #6
Injected61
Junior Member
Tunercat is software for reading and (editing) the chip. The read is then saved to a bin. file in Tunercat.
You make your edits or changes in Tunercat and save those changes to a bin. file which can be programed back to the chip.
Tunercat is not for Programming(burning) the chip. Depending on which type of chip
you use where is different ways to reprogram the chip.
Injected61 is offline   Reply With Quote
Old 12-12-2009, 02:24 PM   #7
JackDidley
CF Senior Member
JackDidley's Avatar
Quote:
Go to Moates.net and get Tunerpro RT and all the hardware and software you need. Most of the software is free. The hard ware is inexpensive and user friendly.
JackDidley is offline   Reply With Quote
Reload this Page anyone wanna program a sd prom?
Tags
corvette, progremming, prom
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
