Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C4 Scan & Tune C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2009, 09:35 PM   #1
mbowers13
CF Senior Member
mbowers13's Avatar
Default LT1 F body vs. Y body tune
Ok so I did some searching but didn't find much. I have a 95 Firebird Formula that has had a tune done by previous owner. Previous owner also said he could tell a decent improvement in before & after performance wise.
I also have a 95 bone stock Corvette. Both are A4, K&N, Magnaflow, stock long block equipped. Only difference is the Fbody has LT headers. I am wondering if I can upload the tune from the Fbody to the Ybody ECM with no side effects?
Has anyone else done this or know someone who has? Thanks in advance.
mbowers13 is offline   Reply With Quote
Old 11-22-2009, 06:58 AM   #2
rodj
CF Senior Member
rodj's Avatar
Does the Firebird have a CCM?
The 90+ Vettes had a CCM and the ECM had to see a signal from the CCM before it would pulse the injectors.
I know of people who have run 90 -92 F-body tunes
( had no CCM ) in 90-91 Vettes so as to bypass this requirement because they have removed the CCM ( for track use ) from their cars
rodj is online now   Reply With Quote
Old 11-22-2009, 05:31 PM   #3
mbowers13
CF Senior Member
mbowers13's Avatar
I'm a little new to tuning. CCM = Chassis Control Module(?), I'm not sure. I'm starting to lean against just uploading the tune. I'm doing more comparison with it vs the Vette bin and make adjustments here and there.
Thank you for your answer rodj. I did some searching for CCM, found this thread and after reading it I believe it would be safe not to use it for anything other than reference.
Edit: I see CCM stands for Command Control Module. Thanks again.
http://www.fuelinjection.com/portinj.html
Old 11-22-2009, 11:24 PM   #4
rodj
CF Senior Member
rodj's Avatar
Quote:
I see no reason why you can't cut and paste the important calibrations (SA , Fueling ,etc ) from the F body to the Vette tune.Would not be changing anything as far as the CCM handshake goes
You save your original Vette tune as a backup and mod a copy
Old 11-23-2009, 06:41 PM   #5
mbowers13
CF Senior Member
mbowers13's Avatar
Yea that's what I'll end up doing. Thanks again for good advice Rod.
Reload this Page LT1 F body vs. Y body tune
Tags
94, 95, body, command, control, corvette, fbody, forums, lt1, module, pcm, tune, tuney, vette, ybody
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
