Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2009, 08:01 PM   #1
Bulldog Steve
CF Senior Member
Bulldog Steve's Avatar
Send a message via AIM to Bulldog Steve
Default Scanner
Have a 1990 and want to buy a scanner or a program to check for codes and see what the systems are doing can you guys point me in the right direction.
Right now i have a service abs light on and have the fsm but it wont pull and codes with the paper clip. I forgot about the the scan and tune section i also have a post in tech.
Steve
Bulldog Steve is offline   Reply With Quote
Old 11-10-2009, 10:48 PM   #2
DBall
CF Senior Member
DBall's Avatar
Download the datamaster program and get the ALDL cables with a USB plug from Andrew Mattei at AKM cables or Gary at TTS systems from Datamaster. Good info and you get 20 free scans before the $85 lifetime software charge. It works great on my mod L-98 383 which DOES need a tune with 30 lbs injectors, etc, etc. They will help you a great deal. Good luck.
DBall is offline   Reply With Quote
Old 11-10-2009, 11:14 PM   #3
Bulldog Steve
CF Senior Member
Is it datamaster.com
Steve
Old 11-11-2009, 08:24 AM   #4
rodj
CF Senior Member
rodj's Avatar
Quote:
http://www.ttspowersystems.com/DataM...downloads.html
You need the DM35x8D file
ALDL to USB cable here $60
http://www.aldlcable.com/
Also considerr TunerPro RT ; unlimited datalogs
http://tunerpro.markmansur.com/downloadApp.htm
You download TP program ;
then download the two files (Bin Definition and ALDL Definition ) relevent to your vehicle (ECM # 1227730 )
http://tunerpro.markmansur.com/downloadBinDefs.htm
rodj is offline   Reply With Quote
Reload this Page Scanner
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ODBII Scanner Recommendation DJD Z06 C5 Scan & Tune 10 09-08-2005 08:48 AM
OBD II scanner - $$$ well spent Vet C6 Corvette General Discussion 17 03-24-2005 11:16 AM
First time with LS1 Edit and Scanner - LTFT results BLOWNZO6 C5 Scan & Tune 11 10-02-2004 01:28 AM
Poll: Best Diagnostic Scanner BQuicksilver C5 Scan & Tune 30 05-25-2004 02:25 AM
!st Time Scanner 1985 L98 Vonstarr C4 Scan & Tune 10 05-14-2004 05:57 AM
Past cali cars, just got new scanner (dial-up beware!) Cali,68,L-79 C3 Tech/Performance 19 04-25-2003 04:20 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
