Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2009, 04:10 PM   #1
96LT4
CF Senior Member
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
96LT4's Avatar
Default More power out of the LT4?
Hi guys! Still thinking there is more to squeeze out of the car to put me up there with the stock C6s. It is not a daily driver, but I do not want to lose drivability either.
Current mods:
LT headers
Hot cam
Tune
Electricwater pump
High flow cats
Corsa exhaust
Heads and intake have not been touched other than valve guides installed and new springs.
I do NOT want to add nitrous or change the rear rear from the stock 3.45
Current HP is 341 rear wheel horsepower or just over 400 the GM way using 15% loss.
Ideas?
__________________
GS, ZR-1, and LT4 owner's click here!!
Click the picture for the website and pictures of our 3 Vettes
1996 Red/black/black LT4 convertible with a couple of mods
1969 Camaro RS/SS 427 Convertible
1996 Yellow/black/black LT4 convertible (1 of 11 made)
1995 ZR-1, white with red interior (1 of 13 made)
NCM Lifetime Member #611 @25
http://www.96lt4.com
96LT4 is offline   Reply With Quote
Old 11-06-2009, 09:10 PM   #2
STL94LT1
CF Senior Member
STL94LT1's Avatar
Send a message via AIM to STL94LT1
You wouldn't believe how gears would wake your car up, but you don't want to go that route.
How about a set of the new AFR Eliminator 195 heads?
__________________
2001 White/Black/Black Vert M6/Z51: LPE TT650 580rwhp/540rwtq
1994 White/Red M6 LT1 Corvette: 374rwhp/345rwtq,12.37@119: Heads/Cam/4.10's
2001 Ford Lightning: 425rwhp/503rwtq,12.85@108
2006 Cobalt LS (DD)
STL94LT1 is online now   Reply With Quote
Old 11-08-2009, 09:04 PM   #3
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Head porting + custom cam.
Vis Croceus is offline   Reply With Quote
Old 11-10-2009, 02:11 AM   #4
mtwoolford
CF Senior Member
lets assume, as has been said forever, that an engine is basically a glorified air pump.
look at your airflow in reverse.
low restriction exhaust: done
high flow cats: done
headers: done
larger intake/exhaust valves/ported heads: not done
cam: done
intake manifold: not done
throttle body: not done
mass air flow sensor: not done
mass air flow housing: not done
air filter and air filter housing: not done
The components making up the exhaust side of your engine have been maximized.
Most would argue that aftermarket heads ported with bigger valves would be the biggest single improvement; and few would deny also the most expensive.
For further improvement, that leaves the intake side.
On the intake side, when tested on a stock LT1, a Mid America Motorworks Mass Air Flow Housing (PN 616-002) , VETTE MAGAZINE had this to say:
"We were stunned when the Dynojet registered improvements of 9 rwhp and 7 rwtq precisely what Mid America claims for the unit in its catalogue....Even at its regular price of $99.95, this ones a steal"
I would postulate that on a mildly modified engine such as yours, you would see even more of an improvement.
Good luck, let us know what you decide and how it works out for you.
mtwoolford is offline   Reply With Quote
Old 11-10-2009, 09:38 AM   #5
96LT4
CF Senior Member
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
96LT4's Avatar
I'll check into that one.
Thank you!
Old 11-10-2009, 01:11 PM   #6
95NOSvette
CF Senior Member
95NOSvette's Avatar
(as recommended) Your current set-up would really love some nice (High-End) Cylinder-Head port Work......IMO, (& experience) you really couldn't go wrong with having either www.advancedInduction.com , or Lloyd Elliott @ www.elliottsportworks.com , bring your factory LT-4 castings out nicely.....And (as recommended), a custom grind cam can also help to maximize the combo.... But in all honesty, "If" your really happy with the Hot-Cam (IE: the way it drives /and the decent mileage it still yields), I wouldn't worry about it one bit, I would leave it in...The Hot-Cam will still actually be VERY close (at the track) to what any of the "still streetable" / "similar spec'd", custom grinds will be......this will be especially the case, since you mentioned that you Do Not want to go ANY deeper with your gearing (which of course limits how much more cam timing you can get in there, before you quickly start trading off low-end torque, for upper RPM power)........Having the LT1/LT4 intake manifold ported at these power levels commonly yields a 1-2 MPH trap speed gain without any real torque loss(so it is beneficial to some).....You could then go for a 58mm throttle body at the same time, so that you'd pick up some more substantial power with the two changes at once.....Also, there is honest power to be gained with a well functioning CAI or Ram-Air set-up.....After trying just about every CAI & Ram-Air set-up possible, I stayed with the one from Breathless Performance...it was the only unit that yielded consistent 2-3 MPH differences in my trap speed.......Anyway, this is the route I would go(and have gone in the past)....With everything mentioned (basically FULL bolt-ons) you should be VERY close to the 375-390 RWHP mark even with the HotCam left in place...and trap speeds could easily fall between 118-121 depending on your locals tracks air....see-ya later C6, LOL..........PS: Also, at all costs...stay away from any products that physically change the MAF housing size.....while some (Bone Stock, factory tuned) cars can pick up a VERY small amount of power, because it's lessening an "overly rich" factory condition during power Enrichment / full throttle.....On the other hand, MANY MANY people with non-stock cars have power losses , and peculiar tuning difficulties......Any of the good tuners (even the good mail order guys are SUPER familiar with this) and recommend going back to the factory MAF housing if it was changed...............
95NOSvette is offline   Reply With Quote
Old 11-20-2009, 03:28 PM   #7
mbowers13
CF Senior Member
mbowers13's Avatar
So with 341 rwhp, you are still not keeping up with stock C6's? How far do you feel you are off?
mbowers13 is offline   Reply With Quote
Old 11-27-2009, 10:56 AM   #8
jonecap
CF Senior Member
jonecap's Avatar
With the exact same mods that you have (except I have a Magnaflow exhaust instead of Corsa) mine made 354rwhp and 348rwtq with a spot on tune. Different dynos will produce different results, but there may be a little bit more left in really dialing in your tune.
__________________
'02 Z06 Electron Blue - 10.78 @ 135.71 P1SC at 7psi
Sold but not forgotten:
'02 Z06 Silver - 11.58 @ 117.40 CAI & ET Streets only - #2 on the C5Z Fast List
'96 CE LT4
11.65 @ 118.76 LT4 hotcam, gears, tires, and exhaust
10.72 @ 128.90 on the jug
'90 Z51 6 speed- 13.10 @ 105.07 with lots of bolt-ons
jonecap is offline   Reply With Quote
Old 11-28-2009, 03:41 PM   #9
aboatguy
CF Senior Member
aboatguy's Avatar
Quote:
A little bit of tweaking from AI will put you in a whole new neighborhood power wise.
Mike
aboatguy is offline   Reply With Quote
Old 12-02-2009, 08:25 AM   #10
96LT4
CF Senior Member
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
96LT4's Avatar
I've ordered this part...it's on sale for less than $60 shipped, so we'll see.
Old 12-02-2009, 08:26 AM   #11
96LT4
CF Senior Member
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
96LT4's Avatar
Quote:
The one C6 I ran with got left behind. I just want more....
Old 12-07-2009, 04:58 PM   #12
5abivt
CF Senior Member
5abivt's Avatar
Sounds like you haven't heard the saying 'all the power is in the cylinder heads'. Get them ported and you will see the biggest gains vs any mod you currently have.
5abivt is offline   Reply With Quote
Old 12-07-2009, 06:15 PM   #13
bnio
CF Member
Cylinder heads cylinder heads cylinder heads!!!! These guys are right. Efficiency is all in the heads, TQ HP and MPG comes from good heads. Its the low lift flow that really gives you the kick in the butt and makes for less needed duration in the cam to make it rev due to efficiency increase which equals more HP on top of the benefit of the new airflow. But keep in mind your whole induction and exhaust system will affect the actual flow. If possible flow the intake throttle body etc. on the heads before you assemble so you know whats actually going in the engine, then you will see what you need to improve next. Can't say enough good things about AFR Comp eliminators, go with something excellent out of the box and never look back. Then it all becomes unbolt then bolt on affair. Instant gratification, no waiting for the head porter replacing guides, milling the deck, new locks retainers, new springs, etc. Thats why new you can hardly complain about the price difference because there isn't much of one if you are going to do it properly. I am also a head porter so I have practical experience and knowledge. Like other said its the biggest gain for the money and if you want to make power its the most effective way to go. Also another fact the combustion chambers and port shapes are also constantly being revised and improved which will make noticeable improvements in efficiency and power. Good luck with whatever you do.
bnio is offline   Reply With Quote
Reload this Page More power out of the LT4?
Tags
616002, air, airflow, america, american, corvette, flow, housing, lt4, mass, massairflowsensor, mid, motorworks, pn, sale
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
LT4 High rpm miss / Running out of ideas (long) 96GS#007 C4 Tech/Performance 33 03-03-2004 09:44 AM
?? CC306 and the LT4?? GS345 C4 Tech/Performance 33 02-22-2004 12:49 AM
Hot Cam Replacement Choices - Slightly More Power superlund C4 Tech/Performance 21 01-21-2004 11:50 AM
What aftermarket intakes out there for LT4? fullboogie C4 Tech/Performance 12 12-10-2002 01:30 AM
LT1 AFR heads out of the box 93 ragtop C4 Tech/Performance 13 11-22-2002 04:17 PM
Need advice on the LT4 hot cam conversion. vettedan C4 Tech/Performance 11 11-14-2002 04:58 PM
Is the LT4 worth it? C4 General Discussion 52 05-09-2002 02:39 AM
Pictures of ported LT4 head Mez C4 Tech/Performance 11 11-15-2001 03:51 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
