Car just stopped running. Checked codes and I need help!
I have a 1995 corvette, Auto, 90,000 miles. I have replaced water pump, opti, plugs, wires, etc. The car has been running great all summer long. I had the car out and it just stopped running on the Highway. I pulled several codes which were 16, 21, 22, 23. I did replace the ICM, TPS, ITS, and cleared codes and took the car out and just stopped running. I did keep popping the code for the Throttle Sensor so I put the old one back in and have taken it on short rides and the codes are gone. Is there anything I should look into before taking this on a trip longer than my city???
Any help is appreciated.
Coil might have died suddenly, too. I'd replace both the coil and Ignition Control Module (ICM) as both can be bought for under $100 bones and it's not uncommon for one component to take the other out during cascade failure (as was the case with my '92 when she flat-bedded me several years ago).
