TTS datamaster not working any more. am using an ostrich and tunerproRT on 93 lt1?
I just installed a supercharger on my 93 lt1. I installed 60 lb injectors and a big fuel pump in the tank.
I did have success tuning it on the dyno with tunerproRT (DA2.xds definition file). I am using an Ostrich (a box that plugs into the chip socket) and a USB cable. This is nice because I dont have to burn a chip every time I make a change. Greg Carroll @ blowerworks supplide me with a base tune - which was pretty good.
I need to datalog a couple dragstrip runs. I need to detect if any spark knock is occurring. So I need good resolution so I can catch a single knock sensor event if it occurs.
TunerproRT can datalog, but the resolution is nowhere near as good as TTS datamaser (ie. TTS datamaster was capturing 10 frames of data a second - where as TunerproRT was capturing a frame of data every 1 to 2 seconds.
The car runs mean at WOT and pretty darn good at part throttle also. My complaints are the usual. Split and wandering BLMs (no luck when changing O2's).
