Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-25-2009, 09:46 PM   #1
Red Rocket
CF Senior Member
Red Rocket's Avatar
Default 94 Corvette PCM Mystery
For the past year, my 396 LT1 runs real strong on the dyno. When I get to the track, the car is running 5-6MPH slower and 3-4 tenths higher than previous times at the track. The dyno supports the higher HP and better ET's. Comparing my times with other Corvettes at the track, there is no doubt I'm down 60-70 HP at the track which is not showing up on the dyno.
The issue started when my speedo was jumping all over the place even when not moving. Shop thought it was the speed sensor but recommended replacing the computer. Replaced the computer and still have the same problem.
ASR service light came on and we ended up disconnecting the ASR since it will impact timing and the throttle. Car still having the same problem at the track.
Any thoughts on what can happen at the track that will not show up on the dyno from a PCM standpoint. The problems all started with the supposed initial computer problems.
Red Rocket is offline   Reply With Quote
Old 10-26-2009, 06:28 PM   #2
simple green
CF Senior Member
simple green's Avatar
Just a guess, but maybe you're getting "knock retard" from hard shifting and not when dyno tuning.
simple green is offline   Reply With Quote
Reload this Page 94 Corvette PCM Mystery
Tags
1994, 94, corvette, dyno, forum, pcm, tune
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
