Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C4 Scan & Tune C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-23-2009, 02:22 AM   #1
USAsOnlyWay
CF Senior Member
USAsOnlyWay's Avatar
Default Changing 4+3 Control Tables?
My apologies if this has been answered previously, I did not see it in my searches.
I have an 86 Corvette with 4+3 (http://www.5speeds.com/43table.htm) and custom chip. Currently the only change made to the chip is that the OD does not automatically turn on as with stock.
However, I really would like to be able to control OD on/off with the thumb switch completely (aka set kickdown to TPS voltage of 7 volts or something that would never be acheived.)
I've heard that you can do some re-wiring in such a way that the button on the shifter controls the OD in an on/off manner but is it possible to do this on the chip?
TIA
Also, are there corvette specific xdf, ads, bin etc files that have definitions for the 4+3 that other manual transmission/variations might not show? If so, where can I get them.
Thanks!
USAsOnlyWay is offline   Reply With Quote
Old 10-23-2009, 11:21 AM   #2
89onlyZ51
CF Senior Member
89onlyZ51's Avatar
No re-wiring necessary. OD is controlled in the TCC lockup MPH vs. TPS tables and the TCC Unlock/prevent OD engage speed constant. Just set the lock TPS to 0% for each MPH and set the prevent OD engage constant to 255 mph, and you'll have manual control with the button.
For an '86, you need the "32.xdf" definition file to interpret the calibration data on the chip. You can get it at moates.net (file upload and download area) or tunerpro.net.
89onlyZ51 is offline   Reply With Quote
Old 10-23-2009, 01:23 PM   #3
USAsOnlyWay
CF Senior Member
Awesome! Thanks, that is much better than cutting/splicing wires! I grabbed the 32.xdf off of moates too.
Nice Callaway, I went to UW for my BS. I miss Seattle, it is great up there.
Old 10-23-2009, 03:56 PM   #4
USAsOnlyWay
CF Senior Member
Does anyone have a stock 86 Corvette bin file I can play with the tables in?
TIA
Old 10-23-2009, 05:43 PM   #5
89onlyZ51
CF Senior Member
89onlyZ51's Avatar
You're probably not missing Seattle so much now that summer's over! I came from DC, and the winters here are just plain dreary - not so much the rain but lack of daylight.
This should be a stock '86 4+3 BIN:
86 4+3 bin
Old 10-23-2009, 09:21 PM   #6
USAsOnlyWay
CF Senior Member
Yeah, it really isn't that rainy but overcast, yes. I can't say I miss that, but I'd like a bit more rain than we get now. Plus, that Seattle air. You don't know how clean it is till you've spent time in the California valley air
Thanks for the bin!
Old 10-24-2009, 12:49 PM   #7
Bondami
CF Senior Member
This brings up a question, I recently converted an 85 with 4+3 to a Carb set up because of Bolloxed wiring etc.. so.. Since I have disconnected the TPs and the other engine control sensors.. is this going to cause trouble with the overdrive?? or will it revert to manual without the TPS signal?
Bondami is offline   Reply With Quote
Old 10-30-2009, 07:26 AM   #8
rodj
CF Senior Member
rodj's Avatar
Quote:
Can control manually by switching the O/d relay
Run the tan/blk wire to ground through a switch
(the stock O/d switch is a signal to the computer; not a wire to the O/d itself )
rodj is offline   Reply With Quote
Reload this Page Changing 4+3 Control Tables?
Tags
43, 86, bin, c4, corvette, information, manual, tables, transmission
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
will gen. 6 support 4x3 overdrive ? lead foot 85 vet C4 Forced Induction/Nitrous 11 06-02-2004 11:23 AM
EPROM questions on Fuel regulation vs. engine temp and also adjusting this curve. B84RADR C4 Scan & Tune 20 10-02-2003 07:55 PM
Killed the FP...that did not take too long.... ski_dwn_it C4 Tech/Performance 96 06-26-2003 08:08 AM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
