Quote:
Originally Posted by JackDidley
The integrater, short term numbers are the ecm trying to correct the lean cells. There is a limit to what it can do here. If you have an adjustable fp regulator you can bump up the pressure and see if it helps.
Thanks Jack for the reply, I am trying to understand what is good or bad results. If the the engine is running correctly would I expect to see all white cells? are green cells a better cituation than red cells?
I failed emissions for HC (almost double the limit) the mechanic said it was either running rich or a bad catalytic converter. That is what prompted this test.
Tom
