Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-16-2009, 07:58 PM   #1
55c3pu
Junior Member
Default "SYS" flash
93 with 21000 miles. The speedo section that displays MPG alternately flashes "SYS". All the manual tells me is to see the dealer. Scan tool shows all systems normal, no codes stored. What is causing this?
55c3pu is offline   Reply With Quote
Old 10-16-2009, 08:23 PM   #2
STL94LT1
CF Senior Member
STL94LT1's Avatar
Send a message via AIM to STL94LT1
Probably a weak battery.
__________________
2001 White/Black/Black Vert M6/Z51: LPE TT650 580rwhp/540rwtq
1994 White/Red M6 LT1 Corvette: 374rwhp/345rwtq,12.37@119: Heads/Cam/4.10's
2001 Ford Lightning: 425rwhp/503rwtq,12.85@108
2006 Cobalt LS (DD)
STL94LT1 is offline   Reply With Quote
Old 10-18-2009, 08:09 AM   #3
GS023
CF Senior Member
GS023's Avatar
Quote:
Charge it up!
GS023 is offline   Reply With Quote
Old 10-18-2009, 01:04 PM   #4
robslittleoldv8
Junior Member
The sys message is due to codes stored in your ccm. They wont always set codes if they are for something minor like your climate control. Pull the flash codes using the technique in the GM service manual. Rob
robslittleoldv8 is offline   Reply With Quote
Reload this Page "SYS" flash
Tags
1994, c4, corvette, display, flash, flashes, flashing, message, sys
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
