Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-13-2009, 07:55 PM   #1
bills1985corvette
CF Senior Member
Default Scan Software For A 1985 Corvette
I need help chosing software to use on my laptop. My car is a 1985 Corvette. My computer is a new Dell with the new vista operating system. What software would work best on this car WinALDL, TunerPro, etc. At this point I just want to read ECM output. If I ever am competent I might someday try burning a chip. If someone is currently using a program to download data I would like to know what data is available from that old ECM, I understand it is limited. Lastly once I am able to download this data, how do I know what a normal reading should be. For example, if I take my temperature and I get a temperature of 101.2 I know that it should be close to 98.6 so I know something is wrong. What I need is a book "1985 Corvette Scanning for Dummies". It would be great if someone could post the readout data from an 1985 Corvette. Any help will be greatly appreciated.
bills1985corvette is offline   Reply With Quote
Old 10-14-2009, 09:53 AM   #2
rodj
CF Senior Member
rodj's Avatar
What you need is a real old computer ( the sort people throw away ) running Win 98 or 95. People have reported problems with Vista
TunerPro has definitions for '85 ECM.
If you were to get more serious , the upgade to the later '165 ECM is a worthwhile upgrade as far as data stream and tuning support
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
rodj is offline   Reply With Quote
Old 10-14-2009, 06:49 PM   #3
bills1985corvette
CF Senior Member
WOW the 1986 puts out a lot more data than the 85! Maybe someday I will make the swap. Thanks for the infomation.
Old 10-15-2009, 07:55 AM   #4
rons85
CF Senior Member
rons85's Avatar
There are three options that I am aware of, all that I personally use (or have used) on My 85.
1.)WinALDL, which does work but you have to lie to it about the baud rate. It's the only one of the choices that builds a Table of the BLM values, although I find it of limited usefulness overall. Only does scanning and data loggong, not an editor like the other two programs.
2.)TunerCat or TunerCat RT. The correct definition file is out there, but it does require a bit of massaging to work correctly (whoever wrote it made a couple of errors in addressing the datastream). This is the program I find the easiest, and the one I generally use.
3.)TunerPro. Like TunerCat, the correct definition file is out there. Not as user friendly as TunerCat, but that's just my opinion. Works fine.
All of these run fine under Windows XP. I've no idea what happens under Vista.
Keep in mind that you also need the correct cable to connect with the ALDL plug - one With the 10k (I Think that's the value) resistor.
__________________
'85 automatic coupe. 276K and counting, 330hp Crate Vortec heads, SDPP base manifold, BBK TB, true duals w/3 muffler setup (that's right - 3), driven daily year round - snow tires a Must!
rons85 is offline   Reply With Quote
Reload this Page Scan Software For A 1985 Corvette
Tags
1985, corvette, ecm, vista, winaldl
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Forum ECM-PCM Tuning Section FAQ Marcho Polo C4 Scan & Tune 141 05-18-2011 11:42 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
