Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-04-2009, 06:38 PM   #1
Fonzy
Junior Member
Default Fuel Injectors Question
This is what lead up to this.
http://forums.corvetteforum.com/c4-t...-problems.html
After I took the injectors off on my 84 to clean them and I put them back the car would not start. I would pour fuel down the throat and it would start. So I had someone else try to turn on the car while I watched the injectors. I noticed the passenger injector only dribbled when before it would spray. The driver injector would not even leak dribble or anything when before it too would spray. I took off the injectors and the holders were wet with fuel, so fuel is getting upto the injectors just not pass them.
Is it possible I that I switched the injectors and that's causing the problems. I didn't know that each injector had a designated place, is this true? You can see fuel and bubbles in the screen on the injector.
What is the spring for in the holders?
I appreciate any help.
Fonzy is offline   Reply With Quote
Old 10-04-2009, 09:06 PM   #2
JackDidley
CF Senior Member
JackDidley's Avatar
You may want to post this in C4 tech. Not much traffic here.
JackDidley is offline   Reply With Quote
Reload this Page Fuel Injectors Question
Tags
c4, corvette, fuel, injector, problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
DQ of the Day--Fuel Injectors dock351 C4 Tech/Performance 10 02-17-2005 11:01 PM
How many pounds? 90 L98 fuel injectors. vettefast C4 Tech/Performance 14 09-18-2003 03:02 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
