Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-04-2009, 04:41 PM   #1
aboatguy
CF Senior Member
aboatguy's Avatar
Default Does this look close?
Seems like its finally getting close no vibration, converter is locking...I still have to figure out how to hook up but...How much air should a 355 be moving? Is everything close or do I need to ..... work on exhaust.......air intake system.......?
Just a little LT1 355 with AI heads.
aboatguy is offline   Reply With Quote
Old 10-07-2009, 09:04 PM   #2
aboatguy
CF Senior Member
aboatguy's Avatar
bueller bueller
Old 10-08-2009, 09:43 PM   #3
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
350 g/s is a healthy amount of air. I just pulled up a couple of stock-engine logs and it's around 245 g/s at 5900 rpm.
I've read that a rule of thumb is to shoot for a Baro-Map @WOT of less than 1.5 in-Hg or so. Use the initial Baro reading on startup.
Another thing to look at is, on a WOT run, how much does the MAP value drop off as RPMs increase.
Just stuff I've read, no real expertise...
Vis Croceus is offline   Reply With Quote
Old 10-08-2009, 10:52 PM   #4
aboatguy
CF Senior Member
aboatguy's Avatar
Thanks for the response Its not an anomoly
Although, I cant see 5900 on the log since it revs too fast on that log but on the frames prior to that its 223.43 at 4575 then 271.46 at 5250 and finally the screen shot frame. I'll track the pressure drop at wot.
Looks like a 1.53 ln HG drop from the highest map reading on that particular WOT run to the lowest (same couple of second run)
If that is good it shows that the stock lid and a KN is not bad. If its bad whats better......?
Is 1.53 in HG drop good at 6300 rpm?????
Mike
Reload this Page Does this look close?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Does this look like a deal? Dannoman C1 & C2 Corvettes 13 03-23-2004 09:56 AM
Ultra Low mile 79.How does this happen?? Alwyn678 C3 Tech/Performance 29 10-23-2003 03:08 PM
[Pic/Trivia] What does this look like to you? TIMSPEED C4 Tech/Performance 34 10-17-2003 11:48 PM
How does this look? BAdAzZV8 C4 Scan & Tune 22 04-29-2003 05:29 PM
Adjusted My Valves, Does this sound Right? KYVette90 C4 Tech/Performance 17 01-18-2003 10:27 PM
Does this guy know what he's got.......if it's REAL? 67HEAVEN Factory Correct Resto 21 05-29-2002 11:50 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
