Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-19-2009, 10:33 AM   #1
wire1967
Junior Member
wire1967's Avatar
Default trouble with my 91 idle
I have a 91 and the idle is good until i drive it then the idle goes up to1100-1500 it also goes up and down when you are sitting in park or neutral and wont settle down till i restart the car. The most recent thing i changed to fix it was the fuel pressure regulater diaphram. Any thoughts.
thanks
Larry
wire1967 is offline   Reply With Quote
Old 09-24-2009, 05:41 PM   #2
corvettemike5984
Junior Member
Check tps
corvettemike5984 is offline   Reply With Quote
Old 09-25-2009, 12:33 AM   #3
wire1967
Junior Member
wire1967's Avatar
I have done that it is set correctly.
thanks
any othe thoughts?
Old 09-26-2009, 06:22 PM   #4
Loosenut_Beretta
CF Member
Loosenut_Beretta's Avatar
Send a message via Yahoo to Loosenut_Beretta
Sorry I did't feel like typing it again so if you follow the link, there is your answer.
http://beretta.forumotion.com/car-kn...re-t81.htm#236
Loosenut_Beretta is offline   Reply With Quote
Reload this Page trouble with my 91 idle
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Anyone running no secondaries and closed loop? wdo-mkr C4 ZR-1 Discussion 30 08-31-2005 07:40 PM
Does anyone have Andy's Head/Cam special? MagRed01Atty C5 Tech 17 05-19-2004 09:01 PM
Is a map of ~55 at idle a vacuum leak? ANTI VENOM C4 Scan & Tune 11 01-26-2004 12:43 PM
Just got my Car back after a Fastburn 385 install and have ??'s newowner'91 C4 Tech/Performance 19 01-31-2003 10:23 PM
No faith in Tuner UAWDES1 C5 Scan & Tune 34 12-11-2002 06:03 AM
Hard starting HELP!! DarkoStoj C4 Tech/Performance 12 03-15-2002 06:51 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
