Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C4 Scan & Tune C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-17-2009, 09:54 AM   #1
Bandit1200
Junior Member
Bandit1200's Avatar
Default Code 33 but MAF ok
I'm having a somewhat intermittent issue with my 1989 Corvette where the engine cuts back to idle when the car is in gear and the throttle is pressed to approximately 20%. If held there the SES light will come on after about 5-6 seconds and a code 33 (high voltage MAF) will be stored. The problem is worse on the highway and it will often "cut back" when the throttle is just off idle. If I let off the throttle the engine comes back to life again and will run normally. If I push the throttle from idle past the 30% mark (approximately) then the car accellerates fine and runs very well. If the engine "cuts back" and I push the throttle further the car will spit and sputter and will run very poorly with no performance until I lift my foot and then the car will come back to normal.
It's as if the computer is reading the high voltage at the MAF below 25% throttle and below 2200 RPMs like it should, however changing out the MAF isn't working. Changing out the the MAF supply and burn off relays made no difference either. I've checked all the wires from the MAF to the ECM for continuity and shook them around during the test and no problems there. I've also switched out the TPS and it made no difference.
Has anyone had this issue before? Any ideas?
Thanks,
Andrew
Bandit1200 is offline   Reply With Quote
Reload this Page Code 33 but MAF ok
Tags
33, c4, code, corvette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Code 34 but not the MAF - any experts handy ? Stingraynut C4 Tech/Performance 20 12-21-2004 07:15 PM
Code 33 !!! 1988, Need help from the pro's BigTodd C4 Tech/Performance 21 08-25-2004 05:43 AM
From dead with a code 33 to 55 degrees total timing in one day. Steve85 C4 Tech/Performance 14 12-12-2003 10:05 PM
86 vette code 33 chasenme C4 Scan & Tune 28 11-13-2003 05:46 PM
PLEASE HELP...85 has a CODE 33 and i can't figure it out mike 1985 C4 Tech/Performance 34 06-20-2003 09:49 AM
MAF Code 33 *again* *last time, I swear* jmr302 C4 Tech/Performance 17 06-04-2002 01:03 PM
1986 Corvette - Code 33 Help? pmihaltian C4 Tech/Performance 10 12-22-2001 01:50 PM
Not a Code 32 but a code 33 Thumper C4 Tech/Performance 11 11-28-2001 09:48 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
