Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-13-2009, 09:00 PM   #1
miketo
Junior Member
Default trouble with my 85
I just bought a stocked 85" drove great till it started misbehavin.have code 32 egr & no vacuum to egr solenoid input. car runs good cold and lopes when warmed up. traced vacuum that splits and connects under throttle body then connects to front eecs canister,both have no vacuum
the eecs solenoid has input vacuum but no output vacuum to eecs canister
does this feed both throttle and egr solenoid and causing the problem?
i checked fuel injectors and they all read 16.5 ohms, I have read most of the threads on similar problems and tried most suggestions
when I start it warm, it will start for a sec then shut off, if I take off the air intake, the car starts and stays on
with foul smell and idles eradictly after a while
. any suggestions? hate to see it parked !!!!!
miketo is offline   Reply With Quote
Old 10-15-2009, 08:34 AM   #2
rons85
CF Senior Member
rons85's Avatar
The EGR isn't, or shouldn't be, keeping it from starting or running. No vacuum to the EGR valve means it's closed, or should be. The EGR code is telling you that the valve is Open (and that the base of the valve is hot and staying hot for longer than the ECM thinks it should). The code also could be setting because the Switch it uses is bad - this is actually the usual cause for that code happening, a bad switch, nothing wrong with the EGR valve itself
Do this: unhook (and plug) the vacuum line at the EGR valve itself. Start the thing up and use a screwdriver or small pry bar up underneath the valve to Lift it (you can also do it with a hand vacuum pump hooked to the valve, it's a Pain to get up under the valve in the TPI manifold, but it can be done). At Idle you will be able to tell instantly the difference between valve open and closed, and it Should close under it's internal spring tension. As long as it's Closed it's not bothering anything and the car should start and run normally. There will be an effect on Emissions if the EGR isn't hooked up, but at least you will have found your problem.
There is also the possibility that the valve is Closed, or trying to, and that the port or pintle are fouled with carbon and preventing a good seal. Result - vacuum leak and bad idle.
If the EGR valve isn't Closing then it amounts to a big vacuum leak, which will really mess with the idle, if it'll idle at all. There Should be manifold vacuum at all times at the small port on the bottom of the throttle body, if there isn't then you have something wrong, which Could point to a major vacuum leak somewhere else. Could also be that the port is plugged up - have you removed/inspected/cleaned the TB lately?
By removing the MAF sensor (either by taking it off the TB, or just unplugging it in place) you force a Zero air flow reading and thereby force the ECM into a mode where it ignores that air flow reading and uses a set "lookup" table instead. This is a default or "limp-in" mode, and normally if it'll run, even if poorly, from that table and Won't run from the MAF then the MAF is faulty. Normally. A major vacuum leak will mess with the MAF to the point that it's reading, particularly at idle, is so far below what it Should be that the diagnostics will think the MAF has failed.
Keep in mind that the '85 uses a one-piece control module to power the MAF, not the two relay setup on all other years. I have NEVER seen one of those MAF modules go bad. Never. Not saying it can't happen, but it's about the Last thing I'd be worried about. It's an expensive part to Buy, also..
__________________
'85 automatic coupe. 276K and counting, 330hp Crate Vortec heads, SDPP base manifold, BBK TB, true duals w/3 muffler setup (that's right - 3), driven daily year round - snow tires a Must!
rons85 is offline   Reply With Quote
Old 10-17-2009, 09:33 PM   #3
miketo
Junior Member
thanks for the info, I will do all that was suggested as soon as it stops raining
Old 10-22-2009, 08:24 PM   #4
miketo
Junior Member
ok, so I took the tb apart and found much carbon build up ( snapped one of the torx screws but I was able to remove it). the idle air control valve sensor was black so it was ordered (it will take a few days) is this what is causing the problem? the port under the
tb connecting to the egr solenoid did not seem to have any blockage. the repair manual
indicates that the valve on the idle air control valve should only extend 1" 1/8, I checked it to extend 1" 1/4.
Reload this Page trouble with my 85
Tags
1984, 1985, 33, 85, codee, corvette, eecs, egr, feed, maf, solenoid, start, troubles, vacuum, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Moving to So. Cal with a 85 OSUBUC C4 General Discussion 12 05-21-2004 08:38 PM
The trouble with "tits"! (funny parts story) 69mako C4 General Discussion 32 09-05-2003 12:28 PM
Should I trade my 85 with 383 for a 98 WS6??? Boo383 C4 General Discussion 19 10-15-2002 11:37 AM
anyone have trouble with interior insulation??? MY 95 C4 General Discussion 10 10-02-2002 09:48 AM
Choppy Idle in my 85... Steak C4 Tech/Performance 9 05-25-2002 11:13 AM
trouble with steering :-( Teresa C3 Tech/Performance 26 01-16-2002 07:21 PM
Check out my 85 project . . . danno85 C4 Tech/Performance 42 12-23-2001 01:14 AM
Might have to sell my 85 Mace C4s for Sale/Wanted 15 11-22-2001 07:12 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
