Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-29-2009, 05:44 PM   #1
Billythekid47960
Junior Member
Billythekid47960's Avatar
Default C-4 injection systems and stroker motors
What are the different injection systems on C-4's capable of supporting with injector changes etc. I want to build at least a 406 cid, but more likely a 430 cid engine with agressive cam, good aftermarket heads, around 10.5 to 11.0 compression, and what ever I need to do to fuel system. Any suggetions? Thanks Billy.
Billythekid47960 is offline   Reply With Quote
Old 08-30-2009, 09:17 AM   #2
rodj
CF Senior Member
rodj's Avatar
Tests done on a 383 but still relative
http://www.compcams.com/Community/Ar...?ID=1737510521
rodj is offline   Reply With Quote
Old 08-30-2009, 10:47 AM   #3
ross.rosseland
CF Senior Member
I like the HSR for it's torque compared to the single planes and the miniram, but for a peaky high RPM race engine, the miniram makes a few more HP with it's shorter runners. For a high RPM street/strip, I use the HSR. The single plane might lose some midrange compared to the HSR, but it's easier to adapt to fit (though still not easy), unless you can find or fab a plenum for the HSR.
The engine size will drive the intake port and gasket sizes as they get bigger from 1204 to 1205 to 1206. I had to weld my HSR and port it to fit the 1206 gaskets on my 200 CC heads for my 383. For your 430, use a 1206, and, assuming it's a street car where you care about midrange torque, use a ported HSR if you're up for a challenge to get one to work, or use a miniram as it's a little easier and the torque loss isn't horrible. The single plane would be ok, too, but both that and the miniram will be down some torque compared to the HSR. The article referenced above is a great source. I actually plotted all the charts out in excel and studied them pretty closely for a few days as I did research on the different options.
ross.rosseland is offline   Reply With Quote
Old 08-30-2009, 02:11 PM   #4
89onlyZ51
CF Senior Member
89onlyZ51's Avatar
Are you talking about intakes or fuel injection systems? As far as injection systems go, C4's had a few:
'84 crossfire (twin tbi) - limited tuning capability just because it isn't that popular and you only have 2 injectors that would need to be huge to support any HP.
'85 Tuned Port - this year only had a digital MAF sensor and tuning is also harder/limited because it's a 1-year only thing. Not as much info out there on it.
'86-'89 Tuned Port - MAF system with some changes year to year. These can only directly read airflow into the 250-275hp range due to the MAF sensor used and a limitation in the computer. However, it will support as much HP (800+?) as a set of high impedence injectors will allow (I think they make 75lb 'ers now - don't know how that will idle) through adding fuel in an area of the calibration called "power enrichment".
'90-'91 Tuned Port - did away with the MAF sensor and infers airflow based on engine vacuum, RPM, and other things. Like above, can support as much HP as high impedence injectors will fuel. Unlike the '86-'89 setup, this can be done directly (without resorting to tricks to fool the computer) in non-boosted applications.
Not as familiar with the '92+, but the same comment about supporting as much HP as high impedence injectors allow applies.
The only hitch for all of these systems is tuning a smooth idle can be difficult with long duration/short LSA cams (i.e. aggressive) due to intake reversion caused by the high overlap.
89onlyZ51 is online now   Reply With Quote
Old 10-07-2009, 08:08 PM   #5
Billythekid47960
Junior Member
Thanks for the info.
Reload this Page C-4 injection systems and stroker motors
Tags
85, c4, corvette, injectors, motor, stroker
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
