Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-26-2009, 08:56 PM   #1
cadmaniac
CF Senior Member
cadmaniac's Avatar
Default Wide Band 02 sensor-What to get?
I'm trying to get into tuning my car (1990 vette). It's quite modified. 421 stroker, Mini-ram, Dart pro1 heads, zzx cam, headers, 3000 stall, 3.73's ect.
While I have been doing research, I am getting advise to get a wide band o2 sensor. No problem.....but what part. I don't know which one fit a GM harness, or for my year. Or for that matter if it will be compatible with my obd1 computer.
I've searched the forum, and can't seem to find out much about it.
Thanks in advance,
Gary
cadmaniac is offline   Reply With Quote
Old 08-27-2009, 01:36 AM   #2
89onlyZ51
CF Senior Member
89onlyZ51's Avatar
I have an Innovate LC-2 and am happy with it for my purposes. If you have some kind of data collection box, this will provide wideband data to it as well as feed the car's stock computer through a separate wire.
Innovate's LM-2 performs the same function but has a display and data collection system built-in.
Basically, with these or similar systems, you unplug and unscrew the car's stock oxygen sensor and replace it with the wideband sensor. If the wideband system has a narrowband output, you can get a connector that plugs into the cars stock oxygen sensor harness and feed the stock computer the narrowband data it's expecting (optional, since it will run open loop regardless on full-throttle pulls). Then you either log or display the wideband data and tune to your heart's content.
89onlyZ51 is offline   Reply With Quote
Old 08-27-2009, 06:50 PM   #3
Weav's Vet
CF Senior Member
Support Corvetteforum!
Weav's Vet's Avatar
Send a message via MSN to Weav's Vet
The LM 2 is very nice. I went a little cheaper and got the Innovate LM 1. If you just want to check AFR it works pretty good.
Weav's Vet is offline   Reply With Quote
Old 09-01-2009, 02:20 PM   #4
Speed Direct
Premium Supporting Vendor
Speed Direct's Avatar
We are currently running a group purchase http://forums.corvetteforum.com/c4-s...-purchase.html
Speed Direct is offline   Reply With Quote
Old 09-01-2009, 10:44 PM   #5
RC000E
CF Senior Member
RC000E's Avatar
I recently purchased the Innovate LM2, as it was compatible with the management systems I commonly tune. It's a nice unit though, backlit readout, programmable as usual, and good quality. The sensors are known to burn up easily though, so you have to be cautious when using them. Luckily they are cheap to replace though.
RC000E is offline   Reply With Quote
Reload this Page Wide Band 02 sensor-What to get?
Tags
2001, 52, band, o2, ram, sensor, wide
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
You guys are going to fall over laughing. '06 Quicksilver Z06 C5 Scan & Tune 12 06-03-2005 07:37 PM
tuning at the track with a narrow band o2 class #101 CORKVETTE1 C4 Tech/Performance 29 11-25-2003 04:10 PM
Is 10 lbs of BOOST to high ?? BLUTHUNDER C5 Forced Induction/Nitrous 23 06-03-2003 02:40 PM
Procharger down on power - what to do? SomeDay C5 Forced Induction/Nitrous 14 06-21-2002 01:07 PM
2000 GTS Viper VS 02 Z06 opticZ06 C5 Z06 Discussion 19 11-07-2001 08:08 PM
First results from adding 02 sensor for tuning warhovs C3 Tech/Performance 24 08-07-2001 11:21 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
