32 EGR starts to bug me
Old 05-28-2008, 03:36 PM
frenchyoliver
frenchyoliver's Avatar
Default 32 EGR starts to bug me
Again, the solenoid needs to be repared. Did it last year and not sure it will support a second surgery.
Not difficult to do but i was wondering if this global EGR and air pump nightmare to maintain could be simply canceled.
Air pump , it s easy but the Egr....
Should i leave it? Any downside of propetly cancel it and shut off the code in the ecm?
Old 05-28-2008, 03:44 PM
Randy93
Randy93's Avatar
St. Jude Donor '06
Are you sure it is the solenoid?
I am getting a 32 and my egr passage is blocked, car was running rich.
Old 05-28-2008, 03:58 PM
frenchyoliver
I am about 100% sure. Ecm doesnt know if it s open or not and code 32 appears only when on interstate at a regular speed while engine is cooling down at 160 termostat after beeing hot in city trafic.
If it was cloagued ( excuse my very bad english not sure it s a right word) i would have the code consistently. Solenoid did the same last year due to inside broken wire.
I know this bug well but it s just that i am begining to think about cleaning all those hoses... Wires....bypass... Solenoid.... Etc
When i look at my other vettes than have very neat racing engines i wonder why the heck to keep all those stuff that simply.... Bug me.
Old 05-28-2008, 05:02 PM
Randy93
Randy93's Avatar
St. Jude Donor '06
No, you would only get the code when the egr tries to open the valve.
I only get mine on the highway, to check for a plugged passage is to start the engine and use a screwdriver to open the egr valve and if the engine stumbles, the valve or solenoid is bad and if the engine does not stumble; your egr passage is blocked.
You english is a lot better than some people here in the states!!
Old 05-28-2008, 05:17 PM
frenchyoliver
nice tip. Thanks.
I ll try that this week end.
Old 05-28-2008, 08:19 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
There is a step by step EGR test procedure on my site.
What year Vette??
Old 05-29-2008, 02:51 AM
frenchyoliver
it s a 91.
your website is full of usefull information.
I ll try the complet procedure.
thanks
To 32 EGR starts to bug me
Quick Reply: 32 EGR starts to bug me
