Tunercat Def File Problem
Old 01-01-2008, 02:11 PM
STL94LT1
STL94LT1's Avatar
Default Tunercat Def File Problem
I just had Tunercat send me an updated version of their $EE definition file, and for some reason I can't find the fans on/off for coolant temperature in the ECM Constants tables. Any idea what I'm overlooking?
Old 01-01-2008, 09:56 PM
STL94LT1
STL94LT1's Avatar
OK, I found it. It now has it's own table.
"Fan Enable Coolant Temp vs Speed"
Old 01-02-2008, 02:13 AM
Arkybill
Arkybill's Avatar
Hi,
I've been lurking around here for the last year or so and have finally got Datamaster figured out(Maybe). Can I use tunercat to just change the fan on and off temps?
bill
Old 01-02-2008, 08:44 AM
87FIREREDRAGTOP
87FIREREDRAGTOP's Avatar
Originally Posted by Arkybill
Hi,
bill
As long as its an available option on your ECM. Tunerpro is cheaper though.
Old 01-02-2008, 12:45 PM
STL94LT1
STL94LT1's Avatar
Yes, that's a very simple change.
To Tunercat Def File Problem
Quick Reply: Tunercat Def File Problem
