car is bucking
Old 12-09-2007, 10:59 PM
bigwave71
bigwave71's Avatar
Default car is bucking
was coming home from the track the other day and while cruising down the road the car starts bucking then it would run normal for a little then do it again. it did it a while back so i replaced the fuel pump, seemed ok after that till i went to track again.on the way home from track did it again. its not my ignition box because i hooked directly to coil. i replaced coil to eleminate that so im thinkin maybe tps, any other suggestions?
Old 12-09-2007, 11:15 PM
Carpenter
Carpenter's Avatar
CTS (coolant temp. sensor)
In front, bottom of your water pump.
I am having the exact same symptoms.
Replaced my CTS and it didn't fix. Wiggled the connector and voila....runs perfect (until the next pothole, of course ).
So now, gotta find a replacement connector and get ready for Spring
Old 12-10-2007, 03:15 PM
JCD
JCD's Avatar
Am I reading you right that you have bypassed your Ignition Control Module? My car experianced low speed bucking (1st and 2nd gear) about a week before my ICM gave up the ghost.
Old 12-10-2007, 04:06 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
sounds like mine when I needed to replace the cap & rotor on my opti
Old 12-10-2007, 06:25 PM
Demonic85
Demonic85's Avatar
1. Check for codes.
2. Check all the sensors for proper operation before replacing anything.
3. Ohm the ignition coil and have your ignition module checked.
Old 12-11-2007, 01:49 AM
bigwave71
bigwave71's Avatar
where is the ignition module located on a 93?
Old 12-11-2007, 11:56 AM
LouisvilleLT4
LouisvilleLT4's Avatar
Echoing Demonic85's sentiment. You are going to replace everything right down to your frame rails before you fix this problem if you're just going to buy random parts one at a time until it goes away. Do thorough inspections and diagnostics until you've found something for certain. Don't just guess.
To car is bucking
Quick Reply: car is bucking
