Quote:
Originally Posted by Bullshark
I just purchased the Accel DFI Gen 7 ECU and a universal un-terminated harness for my RamJet 502. My preference is to implement seqential injection, but before I spend the jack to by the Accel dual sync distributor and an ignition control box (which I have very little room for), I want to look into coverting the GM small cap HEI distributor to accomodate a cam sync capability.
Anyone ever done that? or know how?
Bullshark
When I was looking into this about 2 months ago. I opted for the Crank Trigger and IPU from MSD. The dual sync is by far the easiest but, I wanted the accuracy of the crank trigger. Not sure if it offers much advantage to the dual sync. I almost went dual sync route until a friend of mine gave me a new crank trigger which swayed my decision.
If you do the crank trigger. you will have to find bushing to move all your acessarys out 0.300 for MSD Its a PITA but there is enought room with the rack.
The sequential is a nice option and can offer drivability improvements but you will need temp sensors in your exhaust primarys to dial it in. I dont believe it will offer much WOT improvement.
I have it but have not touched the tuning because I don't have the bungs in my headers and a datalogger. Maybe when the turbos go on.
If I was to do it again, I would put a dual synch in.
Good Luck
JW
