Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-12-2006, 01:57 AM   #1
superboop
CF Senior Member
Default error code 54 and 55
I just purchased a 1985 C4 that had a bad tps sensor. The car would idle way up when started and then die down and finally die. You could keep it running by pumping the accelerator until it was warmed up and then it would oscilate but stay running. Once you got it driving it would have a big lag. It would stumble and die at stop signs. I put the new sensor in it and it seemed to fix everything except that it would still idle rough and die at stops signs. That was two days ago that i replaced the sensor. Today I scanned the car and got two error codes, code 55 and 54. I was wondering how to deal with these codes. They seem to have something to do with the fuel pump but it might be teh ECM? Anyone know how to troubleshoot these codes or how to fix them? Any tests that I can run?
superboop is offline   Reply With Quote
Old 11-13-2006, 10:26 AM   #2
AGENT 86
CF Senior Member
AGENT 86's Avatar
http://members.shaw.ca/corvette86/Code%2054.pdf
http://members.shaw.ca/corvette86/Code%2051-53-55.pdf
AGENT 86 is offline   Reply With Quote
Old 11-13-2006, 05:53 PM   #3
superboop
CF Senior Member
Thanks, so I should probably replace my ECM, I don't ever get a check engine light but i guess the element is probably burnt out cause i dont see it when i turn the key on either. Does anyone know if a 1987 ECM will work with a 1985 car, or are there differences?
Old 11-13-2006, 09:13 PM   #4
AGENT 86
CF Senior Member
AGENT 86's Avatar
The 87 ECM will do you no good, you will need to find an 85 ECM(1 year only).
Here is some info on the no SES light
http://members.shaw.ca/corvette86/No...0-%20Light.pdf
This info is from 86 so some info may be different on an 85, but it's better than nothing
Old 11-14-2006, 04:05 PM   #5
RRT vette
CF Senior Member
RRT vette's Avatar
That's correct. Only the a 85 ECM will work with a 85 Corvette. The 86 can use a 86-89 ECM.
RRT vette is offline   Reply With Quote
Reload this Page error code 54 and 55
Tags
1985, 54, 55, 85, code, corvette, corvettecode, diagnostic, error, trouble
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
85 tuning Insane1 C4 Scan & Tune 50 08-05-2005 09:14 AM
Guess what? Replaced my Opti and I'm back where I started...or didn't start. ScaryFast C4 Tech/Performance 55 07-11-2005 08:39 PM
Code 43 on 86 L98 Auto _twisted_ C4 Tech/Performance 10 03-08-2005 10:41 PM
CAT & Surging ??? ECS Guys please read C5kid C5 Forced Induction/Nitrous 22 11-20-2004 12:52 AM
C4 diagnostic codes Toecutter C4 Tech/Performance 14 06-15-2003 11:19 AM
Custom Stealthram plenum picture DiabolicalDave C4 Tech/Performance 32 04-18-2003 12:02 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
