Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-10-2006, 05:47 PM   #1
Darkgh0st
CF Senior Member
Darkgh0st's Avatar
Default Hesitation @ 2k RPM
I bought a cable and I'm running the datamaster software demo. I checked the TPS sensor and it seems to have a clean signal. Not sure what else to check.
It runs fine cold, and pulls hard @ WOT. The only problem is 2,000RPM where it starts bogging down and hesitating.
Any suggestions??
TIA
Darkgh0st is offline   Reply With Quote
Old 11-25-2006, 12:02 AM   #2
pletner
CF Senior Member
pletner's Avatar
I've got the same problem! Anyone know what the heck this is?
__________________
66' L36 factory A.C.vert, resto-mod:496BB,Tremec 5spd.,coilovers,offset trailing arms,poly bushings,Billet Specialties belt set-up,StainlessWorks headers,Steeroids,Hydroboost.92' Auto Coupe:K&N filter,Cut airbox,TB bypass,Stainless Works LT Headers,No cats,X-pipe,dynomax mufflers,2600 stall, PCMforless Chip,11x17 AFS ZR1 wheels,Carbonfiber dash kit,Whiteface gauges,Blackout kit.00' Auto Coupe:K&N filter,Z06 air box lid,red calipers,crossflag exhaust plate,stainless exhaust tips.
pletner is offline   Reply With Quote
Old 11-25-2006, 12:50 AM   #3
STL94LT1
CF Senior Member
STL94LT1's Avatar
Send a message via AIM to STL94LT1
Sounds like a closed loop problem, check your o2 voltage.
__________________
2001 White/Black/Black Vert M6/Z51: LPE TT650 580rwhp/540rwtq
1994 White/Red M6 LT1 Corvette: 374rwhp/345rwtq,12.37@119: Heads/Cam/4.10's
2001 Ford Lightning: 425rwhp/503rwtq,12.85@108
2006 Cobalt LS (DD)
STL94LT1 is offline   Reply With Quote
Old 11-25-2006, 02:01 AM   #4
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Quote:
Scan your ECM and check the o2 voltages when the car is in open loop and when the problem shows up. It sounds to me like the car is leaning out for some reason, and if it is then the o2 sensor voltage will dive down well below .450mV. If it does that then we have to address why. It could be a MAP sensor that is giving an eroneous load signal, for instance if its bad it could report an lower than normal output which would indicate a higher than normal vacuum which to the ECM would mean a lighter engine load. which would mean that the ECM would fuel much leaner. Also it would be a good idea to check your fuel pressure at the problem RPM. MAP sensors are typically a very robust sensor, they don't go bad very often.
Just remember high vacuum = <45 Kpa and that also means <2.50 Volts. Low vacuum = > 45 Kpa and > 2.50 Volts. If the MAP sensor is the problem it would show up hot or cold in closed or open loop. The MAP sensor is they primary control element in a speed density strategy. If you have a MAF strategy then that sensor is the primary control element for engine fueling.
tjwong is online now   Reply With Quote
Old 11-25-2006, 02:11 PM   #5
rick lambert
CF Senior Member
rick lambert's Avatar
I had a similar problem in my 87, at 1800 RPMs. I used a noid light to make sure all the injectors were getting the signal...turns out I had one bad injector pigtail. Up to that point I had done an enormous amount of TS.
rick lambert is offline   Reply With Quote
Reload this Page Hesitation @ 2k RPM
Tags
2k, hesitation, rpm
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
First impression 4.10 gears <500 miles Wicked Weasel @ ECS C5 General 38 03-15-2005 05:22 PM
Looking for some help...poor performance. RIC96 C4 Tech/Performance 18 04-30-2004 05:22 PM
need tips on spark tuning... Z06_BluByU C4 Scan & Tune 37 01-28-2004 02:31 PM
LPE 415 Home to BRING DA PAIN!!! DDSLT5 C4 ZR-1 Discussion 24 10-14-2003 04:33 PM
I seem to have some hesitation at around 1500 RPM phrogs C4 ZR-1 Discussion 12 06-28-2002 01:54 AM
oil pressure issue again GlockLT4 C4 Tech/Performance 48 06-06-2002 07:54 PM
Cutting out or bogging near top of RPM's - why? Captain Morgan C3 Tech/Performance 33 01-27-2002 11:59 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
