Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2006, 04:13 PM   #1
jamo4
Junior Member
Default 89 no flashing light in diagnostic mode.
When I plug in a diagnostic tool made for my '89 and turn the ignition switch on, the service engine soon light stays on with no flashing. Please help, thank you.
jamo4 is offline   Reply With Quote
Old 11-08-2006, 08:30 PM   #2
SunCr
CF Senior Member
What Diagnostic Tool are you using? Does the light go out? Do the Range and MPG readouts work when you're driving?
SunCr is offline   Reply With Quote
Old 11-09-2006, 05:40 AM   #3
jamo4
Junior Member
I'm using the Actron CP9001 code scanner. The service soon light stays on constantly when the scanner is used and the range and MPG readings are working when driving.
Old 11-09-2006, 08:13 AM   #4
Sam Lam
CF Senior Member
Sam Lam's Avatar
The SES light should flash when you short pins A to B on the ALDL connector. The SES light will not flash when my scan device is attached to my 89 Vette. I cannot recall if the light is illuminated when the scan tool is attached.
Sam Lam is online now   Reply With Quote
Old 11-09-2006, 12:52 PM   #5
SunCr
CF Senior Member
As above - short the pins to see if it will flash - if not, probably a short to ground in the Light circuit.
Old 11-09-2006, 08:28 PM   #6
rick lambert
CF Senior Member
rick lambert's Avatar
when I'm scanning with my laptop the light doesn't flash.
rick lambert is offline   Reply With Quote
Old 11-11-2006, 12:09 AM   #7
jamo4
Junior Member
I tried connecting terminal A and B, the ses light stayed on with no flashing. If the ses light had a short to ground I don't think it would light up at all. The ses light does go off when the engine is started. Does terminal B go directly to the ECM, if so should I run a ground wire at the ECM where terminal B connects?
Old 11-11-2006, 02:16 PM   #8
SunCr
CF Senior Member
Check Engine Light is powered by the Injector 1 Fuse. ECM drives or grounds the Light when a system fault is detected or it's put in Diagnostic Mode. It's put in Diagnostic Mode by grounding the Diagnostic Signal, Pin B at the link; Pin A9 at the ECM, a 5.5 volt reference. Ground path is to the Engine. You troubleshoot a short to ground by disconnecting the ECM. If the Light goes off, reconnect and jumper a 12 volt test light connected to ground to Pin A9 at the ECM. If that flashes a 12, the Diagnostic line to Pin B is open. If it doesn't, you probably need a new ECM.
Old 11-11-2006, 07:46 PM   #9
jamo4
Junior Member
When the engine was at operating temp the ses light did flash a #12 code constantly in diagnostic mode. When the engine cooled down the ses light stayed on constantly with no flashing in diagonostic mode. Should I still try the last procedure you suggested?
Old 11-11-2006, 09:47 PM   #10
SunCr
CF Senior Member
I'd run both tests because you seem to be saying that it won't provide serial data and there's a steady light. Engine temp doesn't matter - hot or cold it should flash a 12. The outlined tests are for this situation. It's either got a short to ground on the drive side; an open in the diagnostic signal or a funky ECM. The circuit is extemely simple.
If you want to see if it will spit out a trouble code, disconnect the TPS with it running and check for a 22 - though I'd verify the basic circuitry first.
Old 11-13-2006, 10:28 AM   #11
AGENT 86
CF Senior Member
AGENT 86's Avatar
http://members.shaw.ca/corvette86/No...0-%20Light.pdf
AGENT 86 is offline   Reply With Quote
Old 11-19-2006, 04:03 PM   #12
jamo4
Junior Member
I tried the test procedure you suggested, no flashing light. Which solenoids and relays should be checked for resistance before I replace the ECM? Can a defective prom chip inside the ECM also cause this problem?
Old 11-19-2006, 11:27 PM   #13
SunCr
CF Senior Member
There are no solenoids or relays involved. Yes, the Prom could be the problem, but it's more likely to be the ECM. Just be sure you jumpered the diagnostic at the ECM, Pin A9 and that someone was looking at the light as you usually have to lay upside down to access the ECM.
Old 11-20-2006, 05:58 PM   #14
corvette1989bham
CF Senior Member
corvette1989bham's Avatar
ground the terminals manually then report back. NOT using any scan tool or software...paperclip or like only.
corvette1989bham is offline   Reply With Quote
Old 11-20-2006, 08:55 PM   #15
jamo4
Junior Member
After removing the two plugs from the ECM and reconnecting the ses flashes a constant code 12 in diagnostic mode, but the radiator fan also comes on and stays on. Is it normal for the fan to come on during diagnostic mode? I'll probably end up replacing the two plugs going to the ECM eventually.
Old 11-20-2006, 10:25 PM   #16
lefoy84
CF Senior Member
Quote:
Fan on is normal.
lefoy84 is offline   Reply With Quote
Old 11-20-2006, 10:58 PM   #17
Sam Lam
CF Senior Member
Sam Lam's Avatar
Jam04: Before you go and buy another ECM, I suggest you go to your local Auto Zone store and ask for this key:
This key is FREE and you insert it into the right two contact holes in the upper row of the ALDL connector. Turn on the ignition.....do not start the car......and see if the SES light will flash 1 2 1 2 1 2. Make sure you turn off the ignition before removing the ALDL key. Hope this is helpful.
Old 12-16-2006, 09:31 PM   #18
jamo4
Junior Member
Started to have the same problem with the ECM so I replaced with a rebuilt ($79)and now the car runs beautiful. This problem all started with a stall out while driving and intermittent idle problems. After replacing the ECM idle is 1200 rpm on cold starts and 550 rpm when the motor is hot with no stall problems.
Old 12-19-2006, 09:55 PM   #19
SunCr
CF Senior Member
Glad you fixed it but 550 rpms seems a bit low. If your scanner works, see what the target rpm is. Actual should be 50 +/- from target in drive. 100 +/- in neutral or park. Mine (Auto) usually targets 575 with 600 actual in Drive.
Old 06-28-2010, 09:05 PM   #20
bigdan7656
Junior Member
Default New guy needs help
Hi I'm Dan.
I'm having the same problem with my 1988. I've done every diagnostic test and used three new computers and two new proms with the same result no flash and the car runs like crap. The car idles at 1500 rpm and when I put it in drive it stalls and shuts down. So, I went to a junkyard and picked up a ecm and prom from a 1988 chevy s-10 4 cyl and my light will flash. I'm at my wits end.
bigdan7656 is offline   Reply With Quote
Reload this Page 89 no flashing light in diagnostic mode.
Tags
1989, 86, c4, corvette, diagnostic, ecm, fan, flashing, lights, mode, runs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Whats wrong??-SES light and no blink!!89vert 6spd89 C4 Tech/Performance 26 08-27-2003 06:11 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
