Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-07-2006, 05:25 PM   #1
1992B4C
CF Senior Member
1992B4C's Avatar
Default Secondary Coolant fan control
OK, so looking at the wiring daigram for the secondary fan, I see it is controlled by the ECM. This is consistent with the fact that when I put the ECM into diagnostic mode, both fans turn on, like they should.
But then why do I have a temperature switch on the passenger side head? What does it do? I cannot find any diagrams for the 1990 vette referencing it..............
Here is the thread that started my questions
(I am kevosiroc at thirdgen.org)
http://www.thirdgen.org/techboard/di...r-i-think.html
1992B4C is offline   Reply With Quote
Old 11-07-2006, 05:49 PM   #2
1992B4C
CF Senior Member
1992B4C's Avatar
Quote:
OK, to answer my own question (and please correct me if I am wrong), that is the coolant temp sendor for the temp gauge.
Old 11-11-2006, 02:30 PM   #3
SunCr
CF Senior Member
Passenger side head switch (actually a thermistor) controls the temp gage. Primary and Secondary Fan Relays are driven by the ECM based on signals from the Coolant Temp Sensor (below the Throttle Body on the Manifold) or the a/c signal from the Pressure Sensor on the high pressure line. Basically, reach a certain threshold from either and the ECM grounds the Fan Relays. Otherwise, ground the diagnostic link or set a troublecode and the ECM will ground the relays. If you want to troubleshoot, post the specific problems.
SunCr is offline   Reply With Quote
Reload this Page Secondary Coolant fan control
Tags
1990, c5, control, controller, coolant, corvette, corvettte, fan, secondary
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Coolant Temp Sensor? robblk90 C4 Tech/Performance 12 07-18-2011 01:38 PM
Are you still legal (in Texas) without the pre-cats? Tiger Shark C5 Tech 38 09-28-2010 01:46 PM
What the heck is SYS keep blinking on my dash??? ericdiver C4 General Discussion 21 02-24-2005 12:10 AM
Adjustable Automatic Fan Control For Cheap!!!! Wheelman C4 Tech/Performance 27 05-28-2004 03:00 AM
Fan Control Question VetNutJim C4 Tech/Performance 9 05-30-2003 12:20 PM
GAUGES fuse is blowing AGAIN.... Nomar116 C4 Tech/Performance 24 10-13-2001 08:27 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
