Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2006, 08:36 PM   #1
honda hunter
CF Senior Member
Send a message via AIM to honda hunter
Default Target Idle Rpm Vs. Coolant temp (In P/N)
In Deg C from -40 to 32 the RPM is set at 900 after that it gets wierd.
44c / 50 Target Idle Rpm
56c / 37.5 Target Idle Rpm
68c / 50 Target Idle Rpm
80c / 25 Target Idle Rpm
92c / 12.5 Target Idle Rpm
104c / 0 Target Idle Rpm
116c / 37.5 Target Idle Rpm
Is there a reason why the tune would set the Target Idle Rpm like this? Would it help if I made them all 900?
honda hunter is offline   Reply With Quote
Old 11-06-2006, 08:50 PM   #2
scranage
CF Senior Member
Support Corvetteforum!
scranage's Avatar
Are you using TunerPro? I had problems with screwy idle values on a DA2 bin that looked like yours. I went to CATS instead.
scranage is offline   Reply With Quote
Old 11-06-2006, 08:56 PM   #3
honda hunter
CF Senior Member
I'm using Tunercats. Can you describe the problems? I'm having idle issues so I'm trying to track it down.
Old 11-06-2006, 09:55 PM   #4
scranage
CF Senior Member
scranage's Avatar
When I say I had screwy values, I mean my bin in TunerPro showed the exact same values your bin showed, for the P/N table. Obviously any rpm settings that low don't make sense. When I opened the same bin with CATS, the values in the same table were completely different, and they were all ok.
Old 11-06-2006, 11:24 PM   #5
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Quote:
I forget what year computer you're using (and it would be nice if you'd include that kind of info in your threads) ... is this a $EE PCM? If so, it sounds like a $EE/$EEb mixup.
Vis Croceus is offline   Reply With Quote
Old 11-07-2006, 12:32 AM   #6
honda hunter
CF Senior Member
Quote:
I have that info in my sig but sigs here dont show up here automaticly. It's a 93. I think the problems is Im using da3 def to view da2 files.
__________________
~1993 Corvette
Eagle 383 stroker,SRP -5 cc pistons,vented Dynaspark,LT4 ported intake,Canton pan,Meziere water Pump,AFR 190 LE P&P 217cc heads,23X/23X/10X cam,Racetronix 37lbs injectors,Racetronix fuel pump,BBK 58mm Throtle Body,K&N filter,Hooker long tube headers,PCMforLess tune Alvin, and ALOT more not listed ~D44 and TH350 coming soon~
Pics
Complete Mod List
~1997 Mustang Vert (5.4L Lightning Powered S/C GT)
1996 Impalla SS
1998 Camaro SS
Old 11-07-2006, 10:11 AM   #7
scranage
CF Senior Member
scranage's Avatar
I recall I couldn't find a DA2 xdf file for TunerPro and had to use a DA3 instead, and I got the exact same values as you in that table.
Old 11-18-2006, 12:55 PM   #8
MSITuner
Premium Supporting Vendor
MSITuner's Avatar
Send a message via ICQ to MSITuner
You are looking at the HEX numbers. The ecm used Hexidecimal and a multiplyer to get to the idle speed. If you use TUNERCAT it does the math for you so you can read the numbers after the conversion.
If you want to be able to do the conversion your self,
You can use the calculator in windows, go to view, scientific and click on "HEX" put in 50, click on "DECIMIAL" this changes the valuel from 50Hex to 80 Decimal, now multiply the number times 12.5 = 1000.
All the hex values are multiplied times 12.5 in the idle table to arrive at your desired idle speed.
Mark
MSITuner is offline   Reply With Quote
Old 11-18-2006, 12:58 PM   #9
MSITuner
MSITuner's Avatar
I just went back and re-read your post. What I said below works for converting the hex to something readable, but you are using the wrong mask. Try loading the other masks until the numbers make sense.
Sorry.
Mark
Mark
Reload this Page Target Idle Rpm Vs. Coolant temp (In P/N)
Tags
coolant, idle, speed, target, temp
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Crash course in custom chip burning... First impressions... Nomar116 C4 Tech/Performance 16 10-06-2001 11:56 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
