Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2006, 02:08 AM   #1
Shawn_65
CF Senior Member
Shawn_65's Avatar
Default Tune-up
So I got the vette back from the shop after getting the Distributor Cap, Rotor, Coil, Plugs, Wires, Fuel filter, and 8 Injectors(22.5Lb)
The car runs and sounds great, now when I rev it, it kinda pops and it feels like theres a lot of pressure and grumbling, is that normal?
its sounds amazing, and it Accelerates furiously and Smooth. No more Hesitation, the Idle is better(though it jumps a bit sometimes), and it sounds cleaner while cruising.
My major problem is that the MPG went way down, I get 19 on the highway at a very slow speed and I'm averaging 12.6 mpg... even with the few sprints on the highway..this is way to low..
should I take it back and have them check the ECM or what? I dont know whats wrong..I do need an oil change...but the air filter and PCV Valve are clean...
any input will be appreciated
Shawn_65 is offline   Reply With Quote
Old 11-06-2006, 11:56 AM   #2
rick lambert
CF Senior Member
rick lambert's Avatar
I'm gonna bet your 02 sensor is poop, typically the first place we check when mileage go down, could be the cause of your other problem too.
rick lambert is offline   Reply With Quote
Old 11-07-2006, 01:14 AM   #3
Shawn_65
CF Senior Member
Shawn_65's Avatar
hmm, after driving today on the highway..the milage isnt as bad as I thought, but I'll check out that sensor, thanks
Reload this Page Tune-up
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bogging down on hard accel Adam Wartell C3 Tech/Performance 37 06-02-2005 06:40 PM
Anybody ever hear of an "Italian Tune-Up?" eschoendorff C4 Tech/Performance 36 10-14-2004 05:32 PM
Tune up time? 02 batmobile C5 Z06 Discussion 23 08-06-2004 01:55 PM
Maximum Performance Tune-up For Stock L98 828790vetteman C4 Tech/Performance 12 06-26-2004 06:23 AM
Vette Doctors C5R C5 back on the Track runs a few 9.4's @ 147 NA in a tune up for the 26th boweryboy Performance Results 15 06-25-2004 11:22 PM
LAPD's Edit -1 Tune up ROD BROWN C5 Tech 36 11-25-2003 05:35 PM
Is my car totally FUBAR or does it just need a good tune up? Help :( Kale C4 Tech/Performance 41 12-30-2001 04:44 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
