Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-05-2006, 08:06 PM   #1
garkahn90
CF Senior Member
garkahn90's Avatar
Default Idle speed
This is my first time to this section of the forum. The tuning thing sound like a lot of fun. I've read the introduction and now I have some questions.
Looks like there is some investment required. As an alternative are there people out there that make changes for others, or for a fee? Or sell reprogrammed Eproms?
My car is a '90 and completely stock as far as the engine goes. I am going to upgrade my exhaust to an LT1 exhaust and considering 1.6 roller rockers and maybe some porting and polishing. Of course that could change. But with these few changes I don't think any reprogramming would be required. But there are some characterstic that I would like to change. Idle speed is one. Right now my engine idles kind of high, 900 - 1000. I've done all the maintenance so I don't think its anything other than what is programmed in the ECM. One of the other things also has to do with idle speed. I understand that when the car is moving and you let off the throttle the idle speed does not drop to the mininum, for emission purposes. Are these things that can be altered with re-programming?
garkahn90 is offline   Reply With Quote
Old 11-05-2006, 09:50 PM   #2
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Quote:
You stock engine was not programmed to idle at 900-1000. You have mechanical problems.
That's odd that we don't have tuner info in the FAQ...
Yes there are many people who can tune these things. A search in this section or C4tech for "tuner" or "tuning" should turn up some names and reviews.
Vis Croceus is offline   Reply With Quote
Old 11-06-2006, 06:22 AM   #3
garkahn90
CF Senior Member
garkahn90's Avatar
Ok, well let me put the question another way. Can the ECM/ Eprom be reprogrammed to a different idle RPM? Can other Engine speed control characteristics be reprogrammed?
Old 11-07-2006, 03:25 PM   #4
SunCr
CF Senior Member
Yes, Base Idle can be programmed to another number. Stock is spec'd at 100 +/- Actual RPMS from Target in Park/Neutral; 50+/- RPMS in Drive.
Before you do anything, hookup a scanner to record Actual vs. Target RPM and note the Coolant Temp Signal. Post those numbers for further help. Changing anything when there's an issue creates more issues.
SunCr is offline   Reply With Quote
Old 11-08-2006, 02:07 AM   #5
Sam Lam
CF Senior Member
Sam Lam's Avatar
garkahn90: I have to agree with the previous posts in that your car is not programmed to idle at 900 - 1000 RPM. Here are the programmed values for idle for my 89 model Vette and these are stock:
Idle RPM vs. Coolant Temperature
Deg F RPM
306 575.00
284 575.00
262 575.00
241 575.00
219 575.00
198 575.00
176 575.00
154 600.00
133 600.00
111 750.00
90 900.00
68 950.00
46 1050.00
24 1050.00
03 1050.00
-18 1050.00
-40 1050.00
I have a Moates adaptor and now have the idle to be at 700 RPM when the coolant reaches 178 deg F. Before you do the ECM change, you should fix the mechanical or vac problem you currently have.
Sam Lam is offline   Reply With Quote
Reload this Page Idle speed
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Slow to return to idle speed, Help Needed! OzzyC4 C4 Scan & Tune 9 11-07-2005 09:55 AM
Idle speed with A/C 65air_coupe C1 & C2 Corvettes 13 08-11-2005 10:08 AM
What is the correct idle speed? ls5454 C4 Tech/Performance 47 04-12-2005 08:38 PM
Idle speed doesn't return to idle. Jughead C3 Tech/Performance 21 10-24-2004 10:08 AM
Where to shift for best fuel mileage? FASST LN C5 Tech 23 10-18-2004 03:05 PM
Idle speed problems mitch11 C3 Tech/Performance 13 07-21-2004 12:05 AM
To drill the TB or bump the idle speed? C5Noir C5 Tech 26 06-21-2002 09:27 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
