Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-05-2006, 01:40 PM   #1
sami85L98
CF Senior Member
sami85L98's Avatar
Default Could not see Timing marks, Any suggestins
Change Dist cap/rotor/coil by hepertech, plug wires, plugs. And now i cant set timing b/c i cant see timing numbers, I disconnected EST wire, connect rpm pickup on #1 plug wire, i cant see any numbers even if i move dist a little by little.
I cleaned the balancer too, still cant see numbers
I use this balancer and the pointer in that suggested parts. Bought this one as per my engine builder to buy external.
http://store.summitracing.com/partde...0&autoview=sku
Car runs awesome without any issue infact blasted last night to 136 mph without any ping.
Do i have to replace balancer, only 9k miles on this balancer.
Any suggestion(s) why i cant see numbers?.
Thanx all. sami.
__________________
2001 z06: Vararam, Airbridge, Modded Ti Catback, SW LT Headers, 3" cats, X pipe, Koni FSD shocks, fresh fluids, C6 Z shifter, Scorpion Black wheels, Hawk pads, partition, EFilive..
85 L98, white/red, Zr1 Chrome wheels, Forged 383, Lpe 219 cam, Accel/Lpe Base/Super Ram intake, Dart pro 200cc heads, 1.6 RR's, Hooker 2149 headers, 160 *, March pulley kit, 52mm TB, 3.54 gears, 3000 9.5" stall converter, upgraded tranny, MSD 6AL, Jesse azzato chip. 12.08, 116.97, 1.74 60' time. Sold
sami85L98 is offline   Reply With Quote
Old 11-05-2006, 05:20 PM   #2
Trog
CF Senior Member
Trog's Avatar
I usually mark the zero on the balancer w/ a little white paint. Then mark the primary #s on the pointer w/ another color.
Trog is offline   Reply With Quote
Old 11-05-2006, 07:55 PM   #3
John A. Marker
CF Senior Member
John A. Marker's Avatar
Default Double check
Double check to be SURE that you are picking up the impulse from plug wire #1. If you are on another wire, you will not see anything even though the light is flashing.
John A. Marker is offline   Reply With Quote
Old 11-05-2006, 11:56 PM   #4
sami85L98
CF Senior Member
sami85L98's Avatar
Will check tomorrow as i worked today and way too tired. Thanks again for the suggestions. I already bought 2 diff color pens and will use diff timing light. sami
Old 11-06-2006, 08:31 AM   #5
Sam Lam
CF Senior Member
Sam Lam's Avatar
Quote:
as this one is very easy to miss. I usually mark #1 wire distributor nipple with a dap of white paint for ease of identity.
Sam Lam is offline   Reply With Quote
Old 11-06-2006, 03:21 PM   #6
RRT vette
CF Senior Member
RRT vette's Avatar
http://forums.corvetteforum.com/show....php?t=1536382
RRT vette is offline   Reply With Quote
Old 11-07-2006, 03:34 AM   #7
sami85L98
CF Senior Member
sami85L98's Avatar
Thanks RRT, i saw that thread when he first started, thats similer to my problem, again today i marked the hash line with choc piece and still no luck could not see numbers, damn i could not see even that big line.
If u disconnect EST wire and i assume engine warmed up how much rpm at idle u guys r getting (with min idle adjustment). ?
Old 11-07-2006, 05:11 AM   #8
Sam Lam
CF Senior Member
Sam Lam's Avatar
Sami: does your timing light have a little adjustable dial on it? If so, are you setting the dial to "0" before seeking the engine timing? You may be advancing the timing light (and not the engine) with this little dial. With the EST wire disconnected, the RPM should be the normal idle RPM.
Old 11-08-2006, 02:50 PM   #9
JLeatherman
CF Senior Member
JLeatherman's Avatar
I usually had trouble finding the marks as well. I marked Zero with whiteout so it was readily visible and just used a dial back light for my adjustments, setting the light to my target advance and then adjusting the dizzy until the white mark was back at zero. It's a lot easier to just have one mark to find.
JLeatherman is offline   Reply With Quote
Old 11-10-2006, 05:59 AM   #10
sami85L98
CF Senior Member
sami85L98's Avatar
Quote:
sam, yes i do have little adjustable dial on it, no i did not set dial to "0" before seeking engine timing. yep iam advancing dial to see marks. With EST disconnected rpm is around 500-600 rpm. Iam gonna try again gotta figure out before nov, 18th as thats a track day.
Old 11-10-2006, 10:37 AM   #11
Pete K
CF Senior Member
Pete K's Avatar
Good advice. My light does not have the dial back knob. Always check to be sure it is on zero.
Pete K is offline   Reply With Quote
Old 11-11-2006, 12:49 AM   #12
Sam Lam
CF Senior Member
Sam Lam's Avatar
Sami: Your car is running well (if the timing was off as you suggest, the car would run like crap) and you cannot see the "line" on the vibration damper. Turn the little knob counter clockwise to "0" and you may be surprised to "see the light" :Let us know what you find out on this. Regards
Old 11-12-2006, 03:01 PM   #13
BennieC.
CF Senior Member
BennieC.'s Avatar
keep moving you timing light pick up to a different cable until you see the mark. if the pick-up ends up to cable other than #1 spark plug cable, you might have a spun harmonic balancer.
__________________
Bennie Cabacungan
Street & Track Performance
by Auto Start
9882 Waterman Rd. Suite 140
Elk Grove, CA 95624
916-714-2886
www.autostartsmog.com
BennieC. is offline   Reply With Quote
Old 11-15-2006, 01:08 PM   #14
sami85L98
CF Senior Member
sami85L98's Avatar
Actually i able to see the line on balancer, and set it to 2 inches down that line, shut off the car 2 inches down the line its 6*, and while i set this w/EST disconected, rpm was 590 rpm. Car running good but gas mileage went down to 18.X from used to be 22.x on normal city/hwy driving. I will recheck again on nov, 18th track day. Thanks for tips so far.
Reload this Page Could not see Timing marks, Any suggestins
Tags
1984, chevrolet, chevy, corvette, elk, grove, instruction, lam, marks, samuel, timing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
