Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-02-2006, 11:56 PM   #1
TnT76
Junior Member
TnT76's Avatar
Default Help with id of Prom
Hi all, first post for me.
Have been doing the tuning on the prom, eprom etc. ecm for a while but all on our 808 MAP based code here in Australia so bare with me.
Have been asked to fix a lean back fire out the airbox on throttle tip in on an 87 vette auto. It has, what I have been told, a full edelbrock intake kit and a chip. Its sounds like a farly straight forward fix (add ae fuel, check timing and mixtures etc.)
So before I decide to have a go at this MAF system I thought I would look for a spare Prom on ebay and sure enough I found one straight up.
$35.00 cant complain.
But this is what has me a little brain strained from all the reading/searching.
Tha BCC is ABTK-0739 and I cant find it on any of the web based BCC sites. I was told it was out of an 87 vette and run with it installed.
The closest I could find is ABTH-0739, so im wondering if this is the same one but with a typo on the chip or on the net.
Anyone know of this BCC ?
$32 by the way
Thanks for any help.
TnT76 is offline   Reply With Quote
Old 11-03-2006, 10:27 AM   #2
Casethecorvetteman
CF Senior Member
Casethecorvetteman's Avatar
Send a message via MSN to Casethecorvetteman Send a message via Yahoo to Casethecorvetteman Send a message via Skype™ to Casethecorvetteman
Where in Australia are you from? Im from the Sunshine coast in QLD. Are you sure this needs a tune to fix this issue? Youve checked everything to make sure all is well??
Casethecorvetteman is offline   Reply With Quote
Old 11-16-2006, 12:54 AM   #3
MSITuner
Premium Supporting Vendor
MSITuner's Avatar
Send a message via ICQ to MSITuner
Type BCC (letters only)
Type stop if done -> abtk
/ABTK/ ***Found!!!
BCC year is 1987
BCC= ABTK0739 Scan id= 7801 Part number= 16070737
Release date= 06/02/86 Engine size= 5.7 Trans Type= Auto trans
ECM/PCM: ECM #01227165
Used in cars: Chevy
Possibly used in:
CORVETTE
Options:
With GU2 AXLE, REAR, 2.73 RATIO
With L98 5.7L GAS 8 CYL MFI
With MD8 AUTO 4 SPD THM 700 R4
With NA5 FEDERAL REQUIREMENTS
With NM5 EMISSION SYSTEM, NON-CLOSED LOOP (CANADA)
Press enter
MSITuner is offline   Reply With Quote
Reload this Page Help with id of Prom
Tags
01227165, 1987, abtk, corvette, ecm, eprom, id, prom
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
85 tuning Insane1 C4 Scan & Tune 50 08-05-2005 09:14 AM
mailorder chips unlocked kvu C4 Scan & Tune 112 04-14-2005 09:59 PM
need some help how to test injectors and why does my ign module keep burning up? DarkoStoj C4 Tech/Performance 12 04-09-2004 12:56 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
