Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-31-2006, 07:00 PM   #1
rmag240
Junior Member
Default ecm problem?
I have 1984 vette one injector would stop working now @ then removed it take to friends shop we tested @ cleaned it put it back in and nothing removed it take back to shop.Can't get it to work. replaced with rebuilt It worked five min and stoped.how do I test ecm? where is it located? and how much do they cost? Any help would be appreciated
rmag240 is offline   Reply With Quote
Old 11-02-2006, 11:24 AM   #2
RRT vette
CF Senior Member
RRT vette's Avatar
You need to make sure you are getting distrubitor ref pulses to the injector connectors. The one injector you are stating could not be getting siginal to fire or getting a intermittant signal. You can check the connector with a test light or noid light while cranking. Also check the fuses. The ECM is under the passenger side dash. You need to remove the hush panel to see it. It is held in with 2, 10mm bolts then it pulls down and you disconnect the connectors to take it completely out. I don't believe you can test it and needs to be taken to a shop that can do so. Not sure on the price.
You need a FSM (factory service manual) to correctly diagnose your problem.
RRT vette is offline   Reply With Quote
Old 11-02-2006, 01:53 PM   #3
rick lambert
CF Senior Member
rick lambert's Avatar
I believe the 84 is batch fired like later C4s, I really doubt it's the ECM.
What I would do is follow the injector pig tail back to where they all connect and make sure the connection is good at that point...and you should be able to swap the connector (pig tail) with another injector to see if it is the injector or just the wiring. My bets on wiring.
rick lambert is offline   Reply With Quote
Reload this Page ecm problem?
Tags
1994, 1994corvetteecm, corvette, ecm, problems
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Check Engine Light On, ECM Problem? Lovin_my_81 C3 Tech/Performance 13 06-11-2005 10:32 AM
WOT, dies at 2.5Krpm, STUMPED vette_tweak C4 Tech/Performance 16 06-06-2005 12:49 AM
ECM problem?! Hawaiian Punch C4 Tech/Performance 10 12-13-2002 10:54 AM
Changing ECM snyper C4 Scan & Tune 10 05-21-2002 08:55 PM
Upgrading ECM ? fiddleplayer C4 Scan & Tune 12 04-20-2002 02:54 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
