Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-29-2006, 06:17 PM   #1
jeff32463
Junior Member
Default how do I find my broadcast code?
88 coupe.I have never had to know my broadcast code until now. I want Alvin to burn me a chip. He needs the broadcast code from my chip. Where is it and how do I get to it?
jeff32463 is offline   Reply With Quote
Old 10-29-2006, 08:23 PM   #2
scranage
CF Senior Member
Support Corvetteforum!
scranage's Avatar
It sould be right on top of your ecm, at least it is on my 92.
scranage is offline   Reply With Quote
Old 10-29-2006, 09:02 PM   #3
gtadudeoh
Junior Member
There is one possible place on the outside of the ECM case that it can be found. There are also two places on the memcal module inside the ECM. On the case look for a white label with the ECM part number. If it is there, the broadcast code should be in the upper right hand corner and consists of four letters. As for the memcal, there should be a silver colored sticker. It will be either on the top of the blue cover or below the blue cover stuck on the eprom. You should be able to see it through the circular hole in the top of the blue cover. Again, it will be a series of four letters.
gtadudeoh is offline   Reply With Quote
Reload this Page how do I find my broadcast code?
Tags
broadcast, code, ecm
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
