Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-27-2006, 03:11 PM   #1
jimmyu2
CF Senior Member
jimmyu2's Avatar
Send a message via Yahoo to jimmyu2
Default Fuel pump relay
Cay anyone tell me the exact location of the fuel pump relay in a 89 Corvette convertable?
jimmyu2 is offline   Reply With Quote
Old 10-27-2006, 05:45 PM   #2
lefoy84
CF Senior Member
Omy 86 it is on the firewall next to the wiper motor.
lefoy84 is offline   Reply With Quote
Old 10-27-2006, 09:50 PM   #3
jimmya
CF Member
Default relay
my 91 is under the glove box, middle relay of 5.
jimmya is offline   Reply With Quote
Old 10-27-2006, 10:46 PM   #4
lefoy84
CF Senior Member
Quote:
Damn, that would not have been my first choice of locations.
Old 10-27-2006, 11:12 PM   #5
RRT vette
CF Senior Member
RRT vette's Avatar
Doesn't get any more exact that this.
__________________
RRT vette is offline   Reply With Quote
Old 10-28-2006, 12:55 AM   #6
lefoy84
CF Senior Member
Same place as the 86.
Old 10-30-2006, 06:35 PM   #7
black85vette
CF Senior Member
black85vette's Avatar
Default relay
Is a 85' the same?
black85vette is offline   Reply With Quote
Old 10-30-2006, 07:38 PM   #8
RRT vette
CF Senior Member
RRT vette's Avatar
Quote:
Originally Posted by black85vette
Is a 85' the same?
Old 10-30-2006, 07:59 PM   #9
black85vette
CF Senior Member
Default relay
Old 10-31-2006, 02:34 PM   #10
jimmyu2
CF Senior Member
jimmyu2's Avatar
Default Thanks to all
who responded, but the relay you have pictured doesn't look anything like the relay in my 89, but I replaced the relay located in that area anyway.
Now I want to remove the passenger side "glovebox" to get at the ecm. Does anyone know how to do that?
Old 10-31-2006, 11:30 PM   #11
Ricefighter
Junior Member
should jsut have to undo the 3 screws underneath, pull that panel down, undo the 2 screws on either side of the ecm, unplug the harness, and it will just "fall" out.
Ricefighter is offline   Reply With Quote
Old 11-01-2006, 09:01 AM   #12
jimmyu2
CF Senior Member
jimmyu2's Avatar
Default ECM removal
Hmmmm... I removed 3 screws (where the passengers knees are) and took the panel out, after disconnecting the light, but still cant see the ECM. It looks like I have to take the "glove box" out, I've taken every screw I can find out, but (I hate to admit it) the I still cant get the "glove box" out. What the "secret" process?
Old 11-01-2006, 10:37 AM   #13
AGENT 86
CF Senior Member
AGENT 86's Avatar
Get on you back and look up. 2- 10mm screws hold it in place.
Remove the 2 screws and pull it down. You may need to push a few wires around.
AGENT 86 is offline   Reply With Quote
Old 11-01-2006, 11:40 AM   #14
JrRifleCoach
CF Senior Member
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
JrRifleCoach's Avatar
Location: The dumbazz state of the Peoples Republik of Kalifornia -PRC-
While your there inspect the wires for exposed copper. Cover as required.
JrRifleCoach is offline   Reply With Quote
Old 11-01-2006, 11:41 AM   #15
jimmyu2
CF Senior Member
jimmyu2's Avatar
Default I owe
There it is! DUH!!
Thanks guys, now all I gotta do is fix it
Old 11-01-2006, 11:48 AM   #16
jimmyu2
CF Senior Member
jimmyu2's Avatar
Default By the way
I'm planning on making a "jumper" to bypass the function on the ECM that enables the injectors (because of the intermittent nature of my problem engine "shuts down" on rapid accereration)
afterword it will crank, with varified (45 psi) fuel pressure, and spark.
Thanks for all the help
Reload this Page Fuel pump relay
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Does the fuel pump relay have to be replaced? Photomania C4 Tech/Performance 38 08-11-2005 01:44 PM
very frustrated need help, fuel pump??? ravenlunatic C4 Tech/Performance 17 12-07-2004 01:10 AM
HELP PLEASE ! Fuel Pump Relay is Stuck Open, Where is it Located?????? wheeljo2 C4 Tech/Performance 15 07-23-2003 01:50 PM
Where is the fuel pump relay on my '86? Its not by the blower motor vetracer C4 Tech/Performance 9 06-09-2003 10:50 AM
woohoo!! jumped pins A & E on fuel pump relay and got FP!! ColinOpseth C4 Tech/Performance 14 07-13-2002 12:03 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
