Quote:
Originally Posted by tjwong
First thing you need to do is to correct DTC15. It appears that either you have a open circuit to the sensor or that the sensor is bad. Then datalog again and go from there. That error alone will cause the engine to remain in open loop or go in and out of open loop depending on how it fails.
The car is running pig rich. My LTerms are Pegged at 160. Could this be caused by temp sensor issue? If I buy a new sensor how can I first test the wires to insure that's not the real issue? Also I'm getting a temp reading from the sensor on the Datalog. If the sensor was bad wouldnt I be getting a bad reading or no reading?
