Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-19-2006, 11:23 PM   #1
Idburnu
CF Senior Member
Idburnu's Avatar
Default "Life" of a tune?
Okay at the risk of sounding especially retarded, this question has been bothering me for a while and though I think I know the answer, I'm just not sure.
I know on older cars you would "burn" a chip and that was always there either replacing or piggybacking that overrode the factory instructions to keep the custom program. My question is on a car that you have the computer itself, such as the later LT1/LT4's "tuned" or programmed, what happens to that when the battery is removed for a period of time or replaced? Does it revert back to the factory default or somehow is the custom tune now "permanent" unless you change it?
__________________
96 White/Black LT-4, Ported Intake, Stage II Heads, HotCam, CC 1.7 RR, 30lb FMS injectors, 255LPH, 52MM TB, Mezeire HD, SD Timing Chain, TB Bypass, EM Ceramic 1 3/4" Longtubes, Carsound 3" Hi-Flo Cats, B&B X-Pipe & Triflo 3" Catback, SLP Claw, 4.10 Gears, Granatelli MAF, Cryo Halfshafts, Balanced Driveshaft, Hurst Shifter, Z51 Suspension, 30/26mm SB, Koni Yellows, Poly Bushings, RD Racing Cross Brace & Camber Bar, Chrome ZR-1's 17x9.5/17x11 w/Nitto DR's
Idburnu is offline   Reply With Quote
Old 10-19-2006, 11:50 PM   #2
gtadudeoh
Junior Member
The "tune" as you call it is burned or flashed into the memory chip depending on the model year. The older models that require chip removal for changes revert to the "tuned" settings as a start when the battery is removed. As the car is driven changes are recorded to the block learn cells to accomodate changes in the air/fuel ratio that deviate from the tune. It's these changes that are lost when battery power is lost. I'm not sure how the newer models, the flash pcm types, handle this. My experience has been with a '94 that reverted back to "tuned" settings after battery removal, but I can't speak with certainty about all flash type pcm's.
gtadudeoh is offline   Reply With Quote
Old 10-20-2006, 12:16 AM   #3
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Quote:
There is no difference. You are "burning a chip" in both cases.
Vis Croceus is offline   Reply With Quote
Old 10-21-2006, 12:09 AM   #4
drive it
CF Senior Member
Once you "tune" it it doesn't change unless you reprogram it again. Older cars you pull the prom and reflash it, the newer cars you can reflash thru the aldl port. So if you leave the battery off, no you dont loose the reprogram.
drive it is offline   Reply With Quote
Reload this Page "Life" of a tune?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
