Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-17-2006, 05:55 PM   #1
lefoy84
CF Senior Member
Default ARAP on 86
I tried the ARAP $6E bin on my 86. Starts up but SES light is on. When I ground the diagnostic link I don't get any flashes, not even the 12.
Is there something else you must do to run this bin on an 86?
lefoy84 is offline   Reply With Quote
Old 10-17-2006, 08:16 PM   #2
gtadudeoh
Junior Member
Does the fan run when you put the key in the on position?
gtadudeoh is offline   Reply With Quote
Old 10-17-2006, 08:44 PM   #3
-js-
CF Senior Member
-js-'s Avatar
The cold start injector should be disconnected.
ARAP vehicles have the AL heads so timming might knock.
You have programming issues if this is true
-js- is offline   Reply With Quote
Old 10-17-2006, 08:51 PM   #4
lefoy84
CF Senior Member
Solved my own problem! I appparently loaded the bin at the wrong start address for thr EEPROM. Still learning this stuff. Redid it and all is well. Little buggers are particular.
Thanks for the input!
Reload this Page ARAP on 86
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Datamaster Help Please Muffin C4 Scan & Tune 10 08-27-2005 05:16 PM
9th Injector - Really need it? JrRifleCoach C4 Tech/Performance 11 03-10-2005 02:24 AM
chip burners-long crank time with ARAP 6E code solved drive it C4 Tech/Performance 14 08-01-2004 05:38 PM
Superram installed, question about chip change for cold start. bjankuski C4 Tech/Performance 9 01-15-2003 11:16 AM
First Track Results in....Kinda Disappointed :( ski_dwn_it Drag Racing 67 06-20-2002 12:09 PM
Does gm make an stock upgraded prom chip? 89 roadster traxx1 C4 Tech/Performance 10 11-22-2001 06:39 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
