Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-17-2006, 01:14 PM   #1
honda hunter
CF Senior Member
Send a message via AIM to honda hunter
Default Need some help
Can someone look at my tune to see if there is anything wrong with it or anything out of place? Int the thread below I state the issues Im having and I want to be able to rule the tune out.
http://forums.corvetteforum.com/show....php?t=1526124
honda hunter is offline   Reply With Quote
Old 10-17-2006, 02:46 PM   #2
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Remind us again - exactly which parts did you use from the 94 and which from the 93?
Vis Croceus is offline   Reply With Quote
Old 10-17-2006, 02:55 PM   #3
honda hunter
CF Senior Member
Quote:
I reused everything that was on the 94 except the fuel rail. Had to reuse the 93 fuel rail because the 94 camaro fuel rail couldnt be used. I had to stick with the 93 ecm and wiring harness for now.
Old 10-17-2006, 03:00 PM   #4
Vis Croceus
CF Senior Member
Is there any way to hook it up with the 94 PCM?
Since it was working well with that before, seems like that would be a good way to determine if it is the engine/install or the tune.
Old 10-17-2006, 03:05 PM   #5
honda hunter
CF Senior Member
Actually I found a 94 PCM and harness for sale from a Camaro I want to use. I assume all I would need is a maf and all would be well correct?
Old 10-17-2006, 05:42 PM   #6
Vis Croceus
CF Senior Member
Quote:
You don't need a MAF, but if the purpose is to test it with the exact same tune you had in the 94 car, then you'll want to use the MAF.
Injector harness is different - do you have the 93 or 94 harness on the engine now?
Old 10-17-2006, 08:48 PM   #7
honda hunter
CF Senior Member
93 right now.
Reload this Page Need some help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
I need some help in Pa. - Jersey - NYC area Fozzy_Bear Northeast 13 01-21-2005 11:06 AM
1996 Corvette - Auto - 10K Miles - Need some help in pricing V8USA C4s for Sale/Wanted 9 12-04-2004 11:32 AM
Possible new C4 owner - Need some help guys V8USA C4 General Discussion 22 12-02-2004 03:48 PM
I'm 20, and looking to invest in a C3, I need some help RedAudiomobile C3 Tech/Performance 33 08-17-2003 12:06 AM
Need some help tuning..... Phil97SVT C5 Scan & Tune 22 06-10-2003 01:40 AM
3 sets of U-joints in 3000miles. Need some help please. IRON WILL C3 Tech/Performance 18 03-24-2003 10:04 PM
Jim Voyles is at it again!!!! I need some help BubbleHead C4 Parts for Sale/Wanted 25 12-28-2002 10:21 PM
I need some help........ GDaina Factory Correct Resto 24 12-08-2002 06:20 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
