Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-16-2006, 08:15 PM   #1
lefoy84
CF Senior Member
Default What Widebands
What wideband O2 sensors and systems are you all using?
lefoy84 is offline   Reply With Quote
Old 10-17-2006, 04:30 AM   #2
Bad Karma
CF Senior Member
Bad Karma's Avatar
I've used the AEM Gauge type wideband and the Innovative Motorsports LM1.
The AEM is very nice and of the two my preference. Better readout and the option of wiring it up for a basic datalogging function or the ability to switch outputs between a 1v or a 5v output. This can be wired into your stock signal as well as run to the gauge, so you could run this without having to weld in a new bung into the exhaust.
The LM1 is more intended for tuning. But not the best for on the fly tuning the box has a small display and reading as you are makings runs and trying to compare with a laptop screen isn't easy. They have a lot of plug ins for logging and accessories, but this brings up the price.
The one that is probably next on my list is the new Autometer wideband gauges. Probably use this on the Vette, and put the AEM in my Jeep when it gets Mega Squirt.
Bad Karma is online now   Reply With Quote
Old 10-17-2006, 02:42 PM   #3
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Planning to use the LC-1
Vis Croceus is offline   Reply With Quote
Old 10-17-2006, 02:44 PM   #4
lefoy84
CF Senior Member
Thanks for the info!! Which AEM do you have. I am considering the 30-4100. That and the Moates Ostrich should allow me to make on the fly changes.
Old 10-18-2006, 06:21 PM   #5
Bad Karma
CF Senior Member
Bad Karma's Avatar
I used the 30-4111 - Black Face with Black Bezel (30-4121, 30-4211 & 30-4221 Are all the same just different choices for colors).
* These are a single channel gauge part numbers only.
If you want to run dual O2 sensors (one for each bank), you will need the UEGO controller, and then a gauge or 2 to monitor readout(s).
You could always run two single gauges and use the 1v output on each to run into the stock ECU. This is probably cheaper than the controller and two gauge faces for monitoring.
Old 10-19-2006, 09:40 PM   #6
gtadudeoh
Junior Member
I use the LM-1. It allows me to connect the auxbox and do standalone datalogging. I also use it to feed the second analog output into the 3 channel A/D interface for the autoprom, which allows for real time monitoring and on the fly program changing in the emulation mode. The auxbox has some great features, but the setup is a little expensive. It has two built in accelerometers that can give you HP and G's. It's very versatile. I have never used another brand, so I'm not going to knock anyone's equipment. Just thought I would share my 2 cents.
gtadudeoh is offline   Reply With Quote
Reload this Page What Widebands
Tags
304100, aem, autoprom, moates
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
VCM Suite 1.7.0 Available Now!! Ken@HPTuners C5 Scan & Tune 15 07-23-2011 11:50 AM
Ptk Project NICK YOSKIN C5 Forced Induction/Nitrous 275 07-26-2005 10:27 AM
HP Tuners... Phil97SVT C5 Scan & Tune 17 05-22-2005 08:16 PM
Do I need to go to 30# injectors??? Strike3 C4 Tech/Performance 214 05-21-2005 02:51 AM
It's official: 2001 Millenium Yellow Z06 for sale, 373 cubic inch 550hp F1RZ06 C5 Corvettes for Sale 18 08-10-2004 09:19 AM
FS: ARE LS6 422 7.0l Godspeed C5 Parts for Sale/Wanted 13 02-25-2002 01:04 AM
Getting a rollbar for the hardtop! Godspeed C5 Tech 37 12-28-2001 12:52 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
